Trailing arm welding
Old Jan 18, 2014 | 11:40 PM
akdale's Avatar
akdale
Default Trailing arm welding
I am thinking about welding my own TA's up rather than buying new ones. I am replacing bushings and doing some other work so they will be off the car. Anyone done this? Plan on doing small sections at a time to avoid overheating or warping. Reason is I have heard the stitch welds are points of failure for high HP cars and my HP is climbing steady through the winter.
Old Jan 18, 2014 | 11:57 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
I bought a set of double offset trailing arms from VanSteel.
I wound up boxing them in Welded them up with a Tig welder.
No problems with twisting or warping.
If you plan on making your own I'd suggest using some sort of Jig
Old Jan 19, 2014 | 12:01 AM
Solid LT1's Avatar
Solid LT1
If you don't build a jig to keep everything straight, you run the possibility of warping your arms when welding them. I probably have some good used California cores around, $200 for a pair of straight clean good metal arms (cant say rust free but free of that cancer I see so often in the cars from other states.)
Old Jan 19, 2014 | 09:08 AM
dtamustang's Avatar
dtamustang
I welded mine .....small sections at a time. if they warped or twisted I can't tell , the alignment after the welding was problem free and the car drives like it should. I welded mine more for cleaning up the look of the arms than strength. all things considered it was worth the time and effort , I say go for it
Old Jan 19, 2014 | 01:49 PM
HBZ_81_C3's Avatar
HBZ_81_C3
Get out the MIG and spray wire!
When I welded mine, I tacked between the original welds first, then ground the original welds to an acceptable point to weld over. The factory welds were horrible.
Once that was done I clamped them to the table and welded them up.
I bead blasted the arms prior to working on them.
Old Jan 20, 2014 | 04:25 PM
akdale's Avatar
akdale
Thanks guys, looks like I'M digging out the welder
To Trailing arm welding
