Starter won't disengage
I've already replaced the ignition switch. Right after replacing the switch, it sounded like I fixed the problem, I would turn the car to run, then back off the key and the starter would disengage. However, it seems this only lasted about two goes before it started doing the same thing it did before I replaced the ignition switch. When I turn the car over, then back off the key, the starter still stays engaged, and will not turn off until you disconnect the battery. Any ideas on what the problem may be?
buy a new/rebuilt drive, or read the following link if you wish to
repair it yourself:
http://www.howacarworks.com/ignition...he-bendix-gear
The key should easily pop-back from the"Crank" position, to the "Run" position by itself when released.
If the rod is in a bind....or if the harness-switch is going bad, the starter will act-up (Not to mention faulty solenoid electrical contacts causing the starter to stay engaged).
noonie : Test for power to the purple wire on the starter when returned to the "on" position. If no power, then get into the solenoid/bendix.
Make sure the wires to the solenoid are connected properly per the wiring diagram.
