Supercharged C3
Old Jul 12, 2002 | 12:15 PM
69side's Avatar
69side
Default Supercharged C3
Has anyone tried to fit a supercharger that uses a carburetor box under a C3 hood? Pictures would be great
Old Jul 12, 2002 | 12:17 PM
Fevre's Avatar
Fevre
Default Re: Supercharged C3 (69side)
http://forums.corvetteforum.com/zerothread?id=333805
I still think with some creative plumbing it can be done. Eliminate the stock fan and shroud and it opens up a lot of space in front of the engine.
[Modified by Fevre, 10:22 AM 7/12/2002]
Old Jul 12, 2002 | 01:15 PM
gdh's Avatar
gdh
Default Re: Supercharged C3 (Fevre)
I have been thinking about that down the road as well, could be a real giggle a 355 with a sc. I would love to see that.
Old Jul 12, 2002 | 01:20 PM
Fevre's Avatar
Fevre
Default Re: Supercharged C3 (gdh)
Greg
Keeping the short water pump you might be able to mount the charger unit backwards and down in the open area then route the 'duct' work up and qround to the enclosure. Vorteck sells just the enclosure so really you could use any super charger unit you wanted as long as you could make the duct work work. I wish I had the skills and tools to under take this. Maybe in the future.
Old Jul 12, 2002 | 02:04 PM
Twin_Turbo's Avatar
Twin_Turbo
You posted the same in engines&upgrades.
i posted this there:
Marck
Old Jul 12, 2002 | 02:44 PM
Fevre's Avatar
Fevre
Default Re: Supercharged C3 (Twinnie)
Twinnie
Is that your setup and if if so looks like a winner! Can you run down some of teh details? Like is it s kit (guessing not), what supercharger and carb fitting is that?
:cool:
Old Jul 12, 2002 | 02:48 PM
RatRacer's Avatar
RatRacer
The problem with that setup is it pressurizes the float bowls of the carburetor. This causes all kinds of drivability problems.
Old Jul 12, 2002 | 02:49 PM
Twin_Turbo's Avatar
Twin_Turbo
No, I have twin turbo's :) This thing is built by geoff Jeal, the guy that worked on the LT-5 and did the programming on the CERV (or was it the indy?)
This is my stuff:
Marck
Old Jul 12, 2002 | 03:07 PM
Fevre's Avatar
Fevre
Ah yes I recall seeing that beast a time or two. Is that plastic wrap on the block during a mock up? Looks like it would be interesting to tune but fun to drive.
Old Jul 12, 2002 | 03:17 PM
Twin_Turbo's Avatar
Twin_Turbo
Yeah, it's plastic wrap. The block is empty.
Marck
Old Jul 12, 2002 | 03:19 PM
Fevre's Avatar
Fevre
I take it is isn't complete yet? Any target date?
Old Jul 12, 2002 | 04:06 PM
Twin_Turbo's Avatar
Twin_Turbo
I dunno, I planned on building a 6"rod 350 but have changed my mind to a 406, only drawback is I can't find a suitable 400 block here except for the one a guy is willing to partwith for 700 bucks...
Marck
Old Jul 12, 2002 | 04:25 PM
Fevre's Avatar
Fevre
What about a 383 or 396 in the 350 block? I don't where to get the crank for the 396 but you can get forged 383 cranks from a lot of places. The 406 would be great though.
Old Jul 12, 2002 | 04:37 PM
Twin_Turbo's Avatar
Twin_Turbo
Nah, don''t want a 383. Maybe I'll do a destroked 400 for revs too. Not sure yet. Still need to find a suitable block. I'll build up this one first but I will defenitely change it later on.
Marck
Old Jul 12, 2002 | 04:41 PM
69side's Avatar
69side
Marck (Twinnie)
I saw your other post, thanks for the picture but that isn't what I am
look for.
Old Jul 12, 2002 | 05:14 PM
Twin_Turbo's Avatar
Twin_Turbo
What are you looking for ? A roots type blower?
Marck
Old Jul 12, 2002 | 06:36 PM
A C's Avatar
A C
Cruise-In II Veteran
Default Re: Supercharged C3 (RatRacer)
Could you elaborate on this? I have read two magazine articles involving installation of this assembly, and neither have mentioned any problems. I don't think either car was on the street yet, just the dyno.
AC
To Supercharged C3
Old Jul 12, 2002 | 06:58 PM
RatRacer's Avatar
RatRacer
Default Re: Supercharged C3 (A C)
Sure, the float bowls of any carburetor are vented above the venturis. These vents are at atmospheric pressure. When the blower plumbing is installed in lieu of the old air cleaner, these vents are now put under boosted pressure. Carburetors are not intended to operate this way and it makes the jetting unstable as boost increases and decreases with various loads and rpms. This is why you rarely see centrifugal blowers used with carburetors. It doesn't work well.
A roots style blower, on the other hand, works with a carburetor because the carb sits on top of the blower. This way the vents are vented to atmosheric pressure and the fuel in the bowls is stable regardless of how much boost is happening below the carb.
Old Jul 12, 2002 | 08:43 PM
'79ProwlerOrange's Avatar
'79ProwlerOrange
i just learned my automotive fact for the day. thank you. :cheers:
Old Jul 12, 2002 | 08:55 PM
A C's Avatar
A C
Default Re: Supercharged C3 ('79ProwlerOrange)
What if you simply extended the bowl vents to outside of the carb enclosure?
AC
