Assuming it's a 427 since the 454 wasn't technically available 'till 1970, it'll either end in 6223 (this is the common one) or 7115 if it's the high performance piece. Sorry I can't help more, tagging along...
Definately a 427 and I have seen the L71 referred to as Special High Performance. Any further information would be greatly appreciated.
Correct. L36, L68 427's are referred to as high performance engines, while L71, L71/L89, L88, ZL1 427's are referred to as special high performance engines.
HiPerformance Chevy cranks were Tufftride Treated giving them a harder surface than a conventional forged crank. Tuffride isn't widely done today because it was a cyanide salt bath process. The surface treatment is very shallow but surfaces are harder and more smooth than a raw steel surface. Grinding a crank even just 0.010" undersized can break through this surface treatment. If you want a great crankshaft try giving Bullet Cams a call and see what they can do for you.
A word of caution,a 6223 crank was used in a 396 and a 427,there is a difference. If I remember correctly the 3rd counter weight on a 396 crank was 7/16ths and the 427 was 7/8ths. Tom Wilson's book"how to rebuild your big block Chevy has that info. As far as I know a 7115 crank was only used in the L-88 and ZL-1.
