Starter Heat Soak?
Old Jul 12, 2002 | 08:21 PM
Taijutsu's Avatar
Taijutsu
Default Starter Heat Soak?
This is my first summer w/new engine. First I fix the vapor lock problem" fuel line was on top of valve cover" and now the starter acts like it is not getting any juice! This is after several starts and stops around town on hot day. It started fine earlier in the day. What is "Heat Soak" and how do I fix this. I have seen the blanket that wraps around starter to protect it, do they work? Any other ideas out there? Being left w/car that won't restart sucks! Thanks for the help.
Old Jul 12, 2002 | 08:32 PM
axcelr8's Avatar
axcelr8
Default Re: Starter Heat Soak? (Taijutsu)
Search on heat soak in the threads. I just had a GM Performance Parts Mini Starter and a Morosso heat shield installed. You can also go with a remote solenoid. All the info is in the threads. E-Mail me if you need details!
Dan
:cheers:
Old Jul 12, 2002 | 08:57 PM
Steve Grodin's Avatar
Steve Grodin
Heat shield will help. The problem is in the solenoid. Your chevy dealer sells a replacement spring that will solve this problem. I replaced my spring many years ago and cured the problem. I recently installed headers and still no problem.
Old Jul 12, 2002 | 09:04 PM
axcelr8's Avatar
axcelr8
Default Re: Starter Heat Soak? (Steve Grodin)
Jeebus, ya probably save 300 bucks doin it that way! :eek:
Live and learn, I guess. :D
Old Jul 12, 2002 | 11:58 PM
ksbunting's Avatar
ksbunting
The part number for the spring for the solenoid is AC Delco # 1958679 , Group # 2.108
This has worked for a lot of people and is very low cost.
Old Jul 13, 2002 | 12:19 AM
Steve Grodin
Default Re: Starter Heat Soak? (ksbunting)
Thank you for posting the part # :chevy
Old Jul 13, 2002 | 09:18 AM
Paul L's Avatar
Paul L
Steve,
Excellent tip! If I had known...before I went this expensive route ($180.00US). But no regrets. I have not had a soak problem since the installation.
Old Jul 13, 2002 | 11:27 AM
Steve Grodin
Default Re: Starter Heat Soak? (paul79)
Paul79,
You installed a very nice piece. From what I have heard you shouldn't have any heat soak problems with it. :chevy
Old Jul 13, 2002 | 11:59 AM
Paul L's Avatar
Paul L
I put a Moroso heatshield on it for extra insurance. It has been a year with no problems at all. Except it sounds like a Chrysler when you turn the key ;) . I was somewhat taken aback when I picked it up at the Chev dealer. If you look at the box closely you will note that this "GM Performance Part" is Made in Taiwan?? That puzzled me but it works fine, the quality of machining is excellent. I guess it is time to accept globalization of the automotive market!
[Modified by paul79, 11:00 AM 7/13/2002]
Old Jul 13, 2002 | 02:18 PM
SteveG75's Avatar
SteveG75
I had this problem a couple of weeks ago in Denver. When I drove the Vette up to the house in the mountains, it would not start for about an hour afterwards.
The solution was a Mr. Gasket heat shield ($25) and a new starter solenoid ($15 at Autozone). I actually had to replace the solenoid anyway since the large positive terminal was stripped as I found out later. Actually was a pretty easy job until I broke a spark plug removing the header for access. So a two hour job turned into a two day job with runs to the part store. :smash:
Works great now though and the heat shield looks pretty nice under the headers. :cool:
To Starter Heat Soak?
