Whoa big difference!
Old Jul 13, 2002 | 01:29 AM
vettinator's Avatar
vettinator
Default Whoa big difference!
Just changed my old splitfire plugs to bosch platinums and the wires to MSD superconductorsin my 75 L48. The engine idles better, has faster throttle response, and starts easier. All for about $80.00! The wires on the passenger side were a pain though. Would have had to remove the starter to get the shield off to get them off.
Old Jul 13, 2002 | 01:40 AM
KENS78SILVERANNIV's Avatar
KENS78SILVERANNIV
Default Re: Whoa big difference! (vettinator)
It's amazing what a little tuning up can do. New plugs, wires, check the timing... wham! The car runs better! Sometimes it's easy. :yesnod:
Old Jul 13, 2002 | 01:56 AM
Rockn-Roll's Avatar
Rockn-Roll
Yeah, but the increase in performance also indicates that you weren't getting good ignition prior to the change. That means perhaps some valves may not be sealing well. I recommend doing a compression check in case one of the cylinders isn't like the others. I had a Pinto that I managed to get running well with some Bosch Platinums, then tore the engine apart about five months later and discoverd one exhaust valve with 1/4 of the valve missing, and another exhaust valve with a crack running from lip to stem with only about 1/16 of it missing. It ran great, but was overheating bad.
Old Jul 13, 2002 | 02:05 AM
vettinator's Avatar
vettinator
Default Re: Whoa big difference! (Rockn-Roll)
Good Idea. I had crappy wires on there with splitfire plugs. They only had 7000 miles on them, but that was over 4 summers of driving. The old plugs all looked the same, white and brittle.
Old Jul 13, 2002 | 02:35 AM
Jman's Avatar
Jman
Bosch Platinum plugs are junk. I had nothing but trouble with them, so I went back to good old cheapie Delco plugs.
Old Jul 13, 2002 | 02:37 AM
The_Dude's Avatar
The_Dude
St. Jude Donor '11, '16-'17
Nice sig pic. :cool: How'd the bumpers turn out? :cheers:
Old Jul 13, 2002 | 03:14 AM
Stevo81's Avatar
Stevo81
Would a "leak down" test do better than a compression test? I have never done one and I'm not sure exactly when it would help. :confused:
Old Jul 13, 2002 | 03:28 AM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
Default Re: Whoa big difference! (Stevo)
stevo, basically, you can do a leak down test at the same time you do a compression test. the gauge is slightly different though. on a leak-down test what your looking for is how many PSI each cylinder drops after it has been stopped. i haven't actually done one so i'm just giving you information which may or may not be totally correct. i do know the idea, it's just the actual proceedure i'm not terribly sure of. what you need is a gauge that doesn't have a check valve to hold the pressure in the line. you need a manual relief valve but the idea is to get the compression in the cylinder up and see how much you loose and how rapidly. this all requires that you can stop the engine at TDC with the valves closed, of course. if the pressure in the cylinder bleeds down rapidly, then that is an indication you have internal 'issues' with that cylinder. maybe someone with practical experience can elaborate on how this is done. if nobody answers here, i suggest you go to the engine mod section and ask there. i'm listening too. :cheers:
To Whoa big difference!
