Problem with horn contact/button
Old Feb 3, 2014 | 02:55 PM
kjbuster1's Avatar
kjbuster1
Default Problem with horn contact/button
On my '72 T/T column I can get the horn to work by pressing anywhere on the horn contact plate with the horn button off. With the button in place pressure on one half of the button sounds the horn. Pressure on the other half has no result. Any ideas what is wrong here?
Thanks.
Old Feb 3, 2014 | 03:52 PM
MelWff's Avatar
MelWff
sounds like the horn button is hitting the steering wheel before depressing the contact plate. Does the button have the same clearance all around it's circumference. If not shim with a small washer under the contact plate on the closest holddown screw.
Old Feb 3, 2014 | 05:40 PM
Iceaxe's Avatar
Iceaxe
Sounds like a horn shim issue, a set of three factory horn shims cost under $10.
Old Feb 3, 2014 | 06:27 PM
Jim Shea's Avatar
Jim Shea
Use a small screwdriver blade and pry the horn cap off of the upper horn contact. (Just pulling on the horn cap itself can cause the cap to come apart and you will have even more problems.)
With the cap removed, now depress the part of the contact that the cap snaps into. Press in various sectors of the contact and determine if the horn blows in all sectors. It could be that the upper contact is corroded and certain areas inside the upper contact are "dead" electrically. You may have to order a new upper contact or rebuild the one you have. (There are kits with plastic "rivets" to hold the contact parts apart.)
If the contact seems to work, then determine if shimming the entire contact allows just a bit more travel so that the upper contact works properly.
Jim
Old Feb 4, 2014 | 08:21 AM
kjbuster1's Avatar
kjbuster1
Default '72 horn
Thanks to Melwff, Iceaxe, Jim Shea. You were right. I put a small washer under each leg of the contact plate and the horn works.
Thanks, Phil
To Problem with horn contact/button
