Doing control arm bushings... am I missing something?
Old Jul 13, 2002 | 01:18 PM
jerryjfunk's Avatar
jerryjfunk
Default Doing control arm bushings... am I missing something?
I'm doing my control arm bushings, and realized that there appears to be some other rubber parts rotting off of the a frames... It is closer to the middle on each side, and only on the lower frames. I thought that I only needed the bushings... what are these other rubber parts called?
Thanks,
Jerry
Old Jul 13, 2002 | 03:19 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: Doing control arm bushings... am I missing something? (jerryjfunk)
Seems like there may be some rubber bumpers on the lower control arms. These just bolt on. I believe this what you are talking about. I dont have any pictures of mine but I am sure several people on here should have some pics. I can go out and take one and email.
Old Jul 14, 2002 | 08:01 AM
Tom454's Avatar
Tom454
Default Re: Doing control arm bushings... am I missing something? (Eddie 96)
There are two other rubber parts, not including the stabilizer link bushings.
There is a snap-in rubber bumber underneath the upper a-frame, and a bolt on rubber bumber on top of the lower a-frame. They are both (4 total) replaceable.
Also... be sure to avoid bending the a-frames when you install your new bushings. The shafts should turn freely by hand when you are finished.If not, you bent 'em.
To Doing control arm bushings... am I missing something?
