Automatic Transmission Recommendations for an '81
Old Feb 13, 2014 | 07:29 PM
  #61
Chavlik's Avatar
Chavlik
Default Times have changed
The car was built to do 55 on the highway and today's speeds have increased. I can't take my car on a trip unless I trailer it.
Old Feb 13, 2014 | 07:42 PM
  #62
diehrd's Avatar
diehrd
Anyway sure toss a 2004R in it just run it in 3rd in town and I guess use O/D on the highway .. at 65 your at 2560 rpm ? If you cant get a 2004R the 7ooR4 will have added costs for cross member and drive shaft shortening .
With a 200 unit you will be at 1600 at 65 and the torque converter is gonna lock on and off on any grades ..unless you get that feature eliminated .. In town the O/D will dog you right down. Not sure if it is worth going over 65 to limit the car in so many areas with an extra gear but you decide.
Look at the rpm drop , and realize the energy needed to keep the car going is the same but at which RPM is the engine better suited to maintain correct in traffic driving behavior. Thats why when people usually go to the O/D on a carb motor your rear gear should be lower then you have because it gets the motor closer to an rpm it can behave most correctly with.
It also allows gear heads to put a very low gears in for killer acceleration and still have it able to drive on the highway and get ok gas mileage doing it.
Old Feb 14, 2014 | 07:33 AM
  #63
Chavlik's Avatar
Chavlik
What rear end gear ratio would be good?
Old Feb 14, 2014 | 09:24 AM
  #64
diehrd's Avatar
diehrd
3.31 at least 3.54 is about perfect
Old Feb 14, 2014 | 01:06 PM
  #65
lionelhutz's Avatar
lionelhutz
You really need to consider the use and what the owner wants beyond just making broad recommendations.
With a 27" tall tire & 3.08 rear gears;
Code:
Speed       60       70        80
TH350C     2300     2680      3068
200R4      1541     1798      2055
I'd say 1541rpm is rather low for a carb'd engine but 1800rpm should be doable if it's a milder engine that is properly tuned. Well, maybe not if you expect to climb mountains but overall a carb'd engine should be able to pull the car at 70mph down the interstates in much of the US without issue.
finallygotit - I don't believe Tucson, AZ is too hilly but I've never been there so maybe it's hillier then I'd expect. I'd say if you want the OD to make those 75-80mph runs better then go for it. You ~300hp engine should be mild enough it'd pull smoothly at 1800-2000rpm range you'd be running.
Another thing to note is that the 700R4 has a 0.7:1 ratio compared to 0.67:1 for the 200R4. So, the 700R4 will bring the rpm's up just slightly compared to the 200R4. It also have a steeper 1st gear to make taking off from a stop more fun.
Overall, you're likely not using OD unless you're running on the highway with that rear gear ratio but the same basically applies to a 3.08, 3.31 or 3.55 gear. You'll be using 3rd unless you hit the highway.
For a bit I ran my Impala with a 700R4, 27.7" tire & 3.31 gears and it cruised down the highway just fine running ~1700rpm @ 60mph. I did use drive in town - because it would try 4th and lug under certain circumstances. We're talking ~250hp engine here using a 220* duration hydraulic flat tappet cam so fairly mild. I'd bet it has 500-750lbs over a C3.
Another option is to use an 4L60e with a controller. Then, you can program each shift curve so you never lug the engine without any driver intervention required. Just stick it in "OD" and drive.
Old Feb 14, 2014 | 05:07 PM
  #66
finallygotit's Avatar
finallygotit
yeah, I have decided to definitely go to OD with my new 350 and the stock 3.07 rear. If i encounter the "falling on my face" I will use 3rd more and look at changing the rear end.
Tucson has mountains all around, but the highways are flat.
Can't wait to get this thing reassembled!
Old Aug 4, 2020 | 12:42 AM
  #67
Michael Wood's Avatar
Michael Wood
1st Gear
Default Thm350
Originally Posted by diehrd
I am a tranny guy , I dont make a suggestion because I think it is acceptable I post because I know from experience.
HIS BEST choice with those gears on a 1980 with a factory lock up system is the oem th350c .. He gains a lot of hassles going to the 700R4 or the 2004R . I can list each hassle if need be but he gains nothing in way of performance , gas mileage , or driving experience.
Unless he plans for motor and gear upgrades most importantly "gear" up grades a 3.08 diff is a joke for a o/d trans , matter of fact monster and or BTO suggest taller gears with a o/d conversion. I think they say 3.31 and up with higher ratios ideal.
I made a typo earlier ... I meant 45mph .. not 60.. I went with 45 because so much driving is between 45 and 60 that it is a very important speed to consider.. And where he will fall on his face with a o/d trans
I have an 81 vet with a thm 350 that I'm trying to rebuild. But when I look on YouTube every video that I set on thm 350s doesn't look exactly like mine first and foremost in the videos they don't have any solenoids mine does. Also the plate on the valve body is different mine is small I will attach pic . The ones in the videos ate much bigger. Can you help me out. I have the ready of the tranny rebuilt but can't figure out how to put the valve body back together
