How low is too low. I'm may have dropped too much. The scatter shield has about 3 1/2" clearance form the ground; hate to rip out the TKO 500. I know some are lower. Any pics of some low rides?
I actually trimmed the bottom flange on the scatter shield for a little extra clearance. I know I have some pictures of it somewhere but every little bit helps also.
the lowest ive been is 2 1/2 inches im now at 3 1/2 inches ,thats with vb&p 550 front springs cut 1 1/4 coils off and rear vb&p spring with 10 inch bolts.275/50/17 rears and 255/50/17 front. if i run my 18x10 rallys with 295/50/15 and 255/60/15 fronts im at 2 1/2 and i bottom out on oil pan.
Looks like you may get some tire rubbing unless you change the wheel/tire combo. You have to be very aware of any road debris or construction (raised manhole covers) when driving anyway. The exhaust system ends up being the lowest thing to the ground, but knocking off an exhaust pipe isn't nearly as bad as breaking the oil pan.
On my car the suspension is so stiff that I don't worry about bottoming out going over normal bumps. It's the stuff that ends up in the road that concerns me.
Rick B.
yeah the oil pan is my lowest point,my butt puckers up when i see a high manhole.im running sidepipes so exhaust is fine.
Forgot to mention. I have the stock dry sump set up from the LS3 Grand Sport. The oil pan is not lower than the steering ram. It fit in there real nice. I may have to get another set of springs and cut a little less to clear the tires, cut the scatter shield flush, and rearrange the wheel combo. I've already added the 8.5" bolts in the rear.
