Replacing body mounting cushions?
Old Feb 6, 2014 | 04:01 PM
ekimcet's Avatar
ekimcet
Navigator
Default Replacing body mounting cushions?
On page 214 of my 1975 assembly manual I see the locations and proper assembly of these body mounts. Is the replacement of these mounts possible with just a frame jack in my garage or should I have it done at a shop with a lift? Also I did not get new bolts with the kit I purchased. The assembly manual does not give the size of the bolts but part #334766. The only nut shown is for position 1 #3930109. They also show adhesive cement #9981098 is this necessary for urethane bushings?
Mike
Old Feb 6, 2014 | 04:14 PM
donnie1956's Avatar
donnie1956
Search the forum but it can be done with the car on jack stands. Its a tough job but first start by getting some solvent on all the body bolt threads and let soak for a few days. Don't be surprised if a few don't come out and may need to be cut out. 2 and 3 are the toughest as they have a cage nut in the frame.
Old Feb 6, 2014 | 04:39 PM
ekimcet's Avatar
ekimcet
Navigator
Thank you I have a good shop I use and they suggested I replace these bushings
Old Feb 6, 2014 | 07:07 PM
obas's Avatar
obas
Before starting check the structure around the #3 mount by viewing thru the cover plate in the wheel well. This is a heavy corrosion area and you may find the scope of the project expanding.
Old Feb 6, 2014 | 08:41 PM
gcusmano74's Avatar
gcusmano74
Remember that you are working with a very old piece of machinery. Once you start taking things apart, it is absolutely common to find more things that need attention.
We call it the "while I'm at it" syndrome.
Old Feb 6, 2014 | 09:04 PM
Mick71's Avatar
Mick71
St. Jude Donor '13-'14-'15,'21
The body's comin' off!
Old Feb 6, 2014 | 09:45 PM
finallygotit's Avatar
finallygotit
I'll just do this one small thing and everything will be easy...
Old Feb 6, 2014 | 09:47 PM
PeteZO6's Avatar
PeteZO6
I helped my friend Rob remove the body on his '70. The #3 & #4 were problematic. Before you think about installing new body mounts, you're going to have to free up all eight body bolts. Breaking the captive nuts loose or breaking the bolts are what you have to contend with. If/when that happens your job just got very complicated.
Good luck!
Pete
Old Feb 7, 2014 | 08:04 AM
U17's Avatar
U17
My doors ect did not line up... So before messing with hinges I had the mounts replaced.... I had read all the threads in here and knew it was not a job for me.... The shop I use does this on a weekly basis so I took it there.... Had the differential lube changed while it was there.... Best money spent.....
Old Feb 7, 2014 | 08:12 AM
htown81vette's Avatar
htown81vette
wish I had a dollar for evertime I said this, particularly on a C3..
Old Feb 7, 2014 | 09:33 AM
Black_Magic's Avatar
Black_Magic
2020 Corvette of the Year (appearance mods)
C2 of Year Winner (appearance mods) 2019
CI 4-5-7-9-10-11 Car Show Winner
CI 2-3-4-5-6-7-9-10-11 Vet
Here is how-to when I did my '65 mounts. Should be same or very close on C3.
Click Here
George
OLD VS NEW
Old Feb 9, 2014 | 09:20 PM
ekimcet's Avatar
ekimcet
Navigator
Thanks guys, the weather here has been single digits so I have not had the urge yet to lay on the concrete floor but rust buster coming out soon. I took both doors off to replace the pins in the hinges and figured everything would be lighter. I will get it done!
Old Feb 9, 2014 | 10:37 PM
gcusmano74's Avatar
gcusmano74
If you have a coupe, removing the doors will certainly lighten the body without any other issues. If you have a convertible, you must brace up the door openings, or the body will flex and flop around like you wouldn't believe.
Old Feb 10, 2014 | 10:23 AM
labhound's Avatar
labhound
…It looks like the box of new body mounts may sit on my work bench a little longer after reading over the sticky,,,,,maybe when it warms up a little..
Old Feb 10, 2014 | 10:33 AM
Mike Ward's Avatar
Mike Ward
You'll gain very little by changing the body mounts. Aside from looking ugly, what problems are you having with them. I'd leave well enough alone.
Poly bushings vs. rubber are a downgrade and a step backwards in any case.
Old Feb 10, 2014 | 07:43 PM
Keith88's Avatar
Keith88
Here is a post with a number of source links in doing a "partial" lift to replace the mounts.
http://forums.corvetteforum.com/c3-t...-question.html
Old Feb 10, 2014 | 09:59 PM
labhound's Avatar
labhound
I have a big gap on both sides, top of fenders to doors, there's no door sag and the hinges are great. The rear mounts are the worst, I'm using rubber mounts.
To Replacing body mounting cushions?
Old Feb 11, 2014 | 09:46 AM
lvmyvt76's Avatar
lvmyvt76
maybe the nose needs to adjusted up.
Old Feb 11, 2014 | 09:48 AM
donnie1956's Avatar
donnie1956
Post some photos of the gap. Some of the gaps were crappy right from the factory.
Old Feb 11, 2014 | 10:23 AM
Mike Ward's Avatar
Mike Ward
Changing out body mounts to fix gaps can be a nightmare.
