Differential
Old Feb 9, 2014 | 05:28 PM
rays699's Avatar
rays699
Default Differential
HI, HOW DO YOU DRAIN ALL THE OIL OUT OF THE DIFFERENTIAL ON A 69 VETTETO PUT NEW OIL IN ?? RAY
Old Feb 9, 2014 | 05:51 PM
garygnu's Avatar
garygnu
you either remove the entire rear diff and the rear cover .or you use a mity-vac hand pump and some small tubing .you probably won't get all of it out with the hand pump ,but do it every few years and it will help .order some posi additive to add to the new gear lube .
Mooser's Avatar
Mooser
You need to siphon it out using some sort of transfer pump
Get as much as you can and move on
M
Old Feb 9, 2014 | 09:04 PM
509 rat's Avatar
509 rat
I just did, I used a pump then added the oil and gear additive, pain in the rear, only to find out there was a plug on the bottom of the diff.
Old Feb 9, 2014 | 09:11 PM
Mooser's Avatar
Mooser
That would bite.
There is/was a kit available to put a pipe threaded plug into the diffs. I thought about adding one to mine when it was out but then again, with how rarely it'll even get changed, I'll deal with it the hard way.
To the OP
One tip when adding the new fluid (and definitely add the GM posi conditioner), stick a needle through the tube and the bottle lid to prevent the little tube from popping off and ending up in the diff.
M
Old Feb 9, 2014 | 10:04 PM
terrys6t8roadster's Avatar
terrys6t8roadster
I drilled and tapped for 1/8 pipe thread. let drain 4 a day or two while I went to the store bought a fitting or 2 to screw into the fill port along with a 4 foot length of clear hose sit on my scooter to poor the juice into the hose Viola. I always wanted to use that word. T
Old Feb 9, 2014 | 10:14 PM
Duane4238's Avatar
Duane4238
Viola was the name of one of my old girlfriends. I think the word you were looking for was "voila".
Duane
Old Feb 9, 2014 | 10:40 PM
drwet's Avatar
drwet
Duane
No I think he meant he drained the oil into an oversized violin.
Old Feb 10, 2014 | 05:01 AM
terrys6t8roadster
Duane
thanks Duane I needed that first am T
Old Feb 10, 2014 | 07:00 AM
Blue73Shark's Avatar
Blue73Shark
More tips on changing the fluid can be found here:
http://forums.corvetteforum.com/c3-t...fill-pump.html
Fran
Old Feb 10, 2014 | 09:53 AM
thegazman's Avatar
thegazman
Default thegazman
"Corvette Central" sales a differential drain plug kit. A little pricy, but does a good job. If you knew someone who had the tools from the kit, all you would need to buy is the plug.
To Differential
