Gilmer Drive for 1968 427BB
Old Feb 12, 2014 | 07:14 AM
kazzrich's Avatar
kazzrich
Default Gilmer Drive for 1968 427BB
Has anyone done this before. I want to fit a Gilmer to my 427 in 1968 Convertible.
Not sure what water pump I have - are they a long or short pump.
Also have an aftermarket PS unit which appears to be in the way.
Old Feb 12, 2014 | 11:31 AM
MelWff's Avatar
MelWff
you have a short pump
Old Feb 12, 2014 | 11:47 AM
Doug Kraft's Avatar
Doug Kraft
The problem you might have is the length of the belt, depending on where your alt is mounted. I had to get a longer one.
Old Feb 13, 2014 | 10:38 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
If you want the good stuff, Jones Racing Products.
Old Feb 13, 2014 | 10:53 PM
Ray Y's Avatar
Ray Y
I used a setup from Alistair Miller at Millerspeed. It's agreat set up and he will make it work for you. alistair@millerspeed.com
Old Feb 14, 2014 | 09:00 AM
maverickmk's Avatar
maverickmk
Yowza! That's a thing of beauty there
Old Feb 14, 2014 | 01:53 PM
toddalin's Avatar
toddalin
I also have the Millerspeed set-up. Alistair came over to my home, brought it with him, and we installed it here together.
If you watch the current Wheeler Dealers C2 episode on Velocity, you will see my car and engine at 45 sec into the show and you can see the set-up (for a moment).
BTW, Car Craft found ~10 hp using the Millerspeed set-up because of reduced friction and slightly different pulley ratios.
To Gilmer Drive for 1968 427BB
