LS conversion and speedomiter
Old Feb 18, 2014 | 12:22 AM
Tim 1973's Avatar
Tim 1973
Default LS conversion and speedomiter
For those that have done or are working on a LS swap with a 4l60E Transmission how are you dealing with the lack of manual speedometer gear on the Transmission.
I have found that you can purchase a new tail shaft that has both the VSS and manual from
http://www.shiftworks.com/tailhousing.htm#t56
But they are very proud or the tail shaft. 500.00 +
Old Feb 18, 2014 | 12:42 AM
Patro46's Avatar
Patro46
Yup. Aware of that. I was kinda hoping you had came up with an alternative. My tach was mechanical on my 74. That was a project getting it converted to electronic AND keeping the number stencils looking the same between tach and speedo. Unless a cheaper alternative is found, we both may be sheeling out 500 bucks for a 25 dollar sandcast with some milling work
Old Feb 18, 2014 | 12:48 AM
Tim 1973's Avatar
Tim 1973
Yes I switched my tack over to a electronic and switched face plate to keep the same markings.
I keep trying to find another company that is making them. I think 250.00 would be reasonable but 500.00 ouch.. I don't need it right now but would like to have this off my list...
Old Feb 18, 2014 | 12:56 AM
Tim 1973's Avatar
Tim 1973
Patro, Did you look at the 71-80 Camaro Rad from SUPERIOR RADIATOR, the more I look at it I think I'm going to go with it.
Old Feb 18, 2014 | 02:00 AM
jerome1979's Avatar
jerome1979
Other solution is: abbott cable-x
Old Feb 18, 2014 | 01:15 PM
Tim 1973's Avatar
Tim 1973
I have done a little research. Putting a Manual Speedometer adapter where the VSS sensor is then adding a VSS kit might be the way to go.
Advance adapters sells a VSS kit that can be installed. I have a email into there tech department. The adapter kit is 250.00
The manual speedometer adapter appears is a direct fit into the 4l60E where the present VSS is located the adapter for the speedomited is 39.00 on ebay
http://www.advanceadapters.com/produ...-output-shaft/
One Plus for the shiftworks solution is they take your tire size and diff gears and have it all set up so you should not need to mess with getting the speedometer being correct.
Old Feb 18, 2014 | 06:13 PM
lionelhutz's Avatar
lionelhutz
Jags That Run have some parts for installing both a cable drive and a VSS sensor into the tail of the transmission. Here is an example of one of the parts they make to mount both the gear and reluctor onto the tail shaft.
http://jagsthatrun.com/Pages/Parts_4...uctorRing.html
Look around on the site, they have other similar parts too. They're cheaper but you have to tap the sensor right into the case instead of getting that adapter piece. But then the part above also gives you the tab to hold the speedometer drive gear in place. The tailshafts of the 4L60e transmissions generally don't have the hole for the speedometer gear clip.
Here's another link with a different but similar setup.
http://www.jagsthatrun.com/Pages/Spe...tor.html#clamp
I believe to run a speedometer gear adapter you need a 700R4 tailpiece or maybe an older 4L60e one.
Old Feb 18, 2014 | 06:18 PM
lionelhutz's Avatar
lionelhutz
The Shiftworks kit looks to add a 40 pulse reluctor like factory so I'm not sure how they compensate for rear gears or tire diameter.
Old Feb 18, 2014 | 06:47 PM
SH-60B's Avatar
SH-60B
I've been looking at that for my T56 swap.
Old Feb 18, 2014 | 07:03 PM
72LS1Vette's Avatar
72LS1Vette
I use a Cable-X box but Dakota Digital just announced their version of the Cable-X:
http://www.dakotadigital.com/index.c...rod/prd886.htm
They charge $300 for their box. I forget what I paid for my Cable-X but I bought it on ebay from a guy who listed it both as a Buy-It-Now and an auction. I bid the minimum in the auction and won as the only bidder.
Seems like the biggest difference between the two products is the calibration. I calibrated my Cable-X with a GPS and it is very accurate. The Dakota box uses some other form of calibration than DIP switches.
Rick B.
Old Feb 18, 2014 | 07:08 PM
Tim 1973's Avatar
Tim 1973
Changing the tail piece is not a big deal and fairly inexpensive under 40.00 on ebay.
I will take a good look at this when I get back from our local corvette meeting.
Thanks for the link...
Tim
Old Feb 18, 2014 | 07:12 PM
Tim 1973's Avatar
Tim 1973
Rick B.
Thanks Rick,
I will take a look at this solution, but I'm leaning toward having the manual drive cable and VSS on the transmission.
Tim
Old Feb 19, 2014 | 12:39 AM
Tim 1973's Avatar
Tim 1973
lionelhutz,
Thanks so much... Just got my list together.. for about 150.00 I will be set. The speedometer adapter is not listed but will look some more... Its available on ebay... This is what I have been looking for and I will
pass it on to others..
Tim
Old Feb 19, 2014 | 12:58 AM
Tim 1973's Avatar
Tim 1973
They put the 40 pulse wheel in plus the speedometer cable connector with the gears inside just like it was in the 70's the r wheel is to control the shifting with the computer and cable connector for original speedometer.
What lionelhutz posted does the same thing, where the stock R wheel is located on the 4l60E you insert the old style adapter then you add a R wheel on the shaft but save about 350.00
Old Feb 19, 2014 | 01:22 AM
Patro46's Avatar
Patro46
Thanks Rick,
Tim
I am taking a good gander at this solution Tim. They have taken awards for this design, and no gutting the trans and modifying the output shaft! Oh...and it's 200 dollars less! Getting more reasonable now.
Old Feb 19, 2014 | 09:57 AM
lionelhutz's Avatar
lionelhutz
Tim, I was meaning the Shiftworks kit would still require setting the ratios up in the PCM like any other solution. They can get you the right mechanical gear drive parts.
Old Feb 19, 2014 | 10:05 AM
Tim 1973's Avatar
Tim 1973
The speedometer does not touch the PCM in the shift works solution its a direct cable. Now the VSS does go through the PCM but has no impact on the reading on your cable driven speedomiter. The shift works picture does not show it well but spent 30 min on the phone going over how there's works.
To LS conversion and speedomiter
Old Feb 19, 2014 | 04:04 PM
lionelhutz's Avatar
lionelhutz
Yes, I can see what it does.
Pretty much the same thing as the JTR parts I linked too. The kit mounts a gear and reluctor onto the output shaft and the new tailshaft housing has holes to mount both the VSS sensor and the mechanical cable drive. You tell them rear gear and tire and they give you the mechanical drive gears you need so the speedometer works but the PCM still requires setup to match.
Old Feb 19, 2014 | 04:41 PM
Tim 1973's Avatar
Tim 1973
Yes except they do all the work on the housing and you just replace the tail housing with the one they send you. You will still need to put the reluctor ring on the shaft that they send you.
But instead of 150.00 using JTR for kit and purchasing old style speedometer gears and drilling/tapping one hole When I do this I will write it up with links and part numbers it takes to complete the mod. the alternative is 500.00 to (shiftworks) No mater what way you go you are still removing tail housing. 4 bolts..
Thanks for all the input and links.
Old Feb 19, 2014 | 06:11 PM
lionelhutz's Avatar
lionelhutz
Lots of people will find your write-up very useful since the pictures and info are rather lacking on the JTR site.
I was real close to using the JTR parts but then put a Dakota Digital dash into the car instead and ran the tach and speedometer right off the PCM.
