Distributor Rebuild
Old Feb 21, 2014 | 12:05 PM
jnb5101's Avatar
jnb5101
Default Distributor Rebuild
I'm rebuiling the dissy removed from a 69. Surprisingly there is no wear in the cross gear area. Two questions.
Where can the miscellaneous small parts be purchased? I need the cross gear thrust washer and the lubricating wick, and all the parts houses only sell the washer with a new driven gear and no one sells the wick.
When I disassembled the dissy, the dimple on the main gear was pointing away from the rotor tip. I don't want to sound dumb, but I thought that the tip and the dimple should face the same direction. Am I dumb or smart??
Old Feb 21, 2014 | 12:15 PM
MelWff's Avatar
MelWff
Could be my memory but I have no recollection of a lubricating wick in the area of the cross gear. The housing is typically packed with grease. You are correct the dimple and rotor should point the same direction.
Old Feb 21, 2014 | 04:06 PM
Peterbuilt's Avatar
Peterbuilt
The dimple goes on the same side that the rotor faces. It will work backwards but the vacuum advance will end up in an other than stock location.
Old Feb 21, 2014 | 04:08 PM
jnb5101's Avatar
jnb5101
thanks for the replies. corvette america has the thrust washers-$1.99 plus shipping!
To Distributor Rebuild
