Only one tire spins
Old Jul 15, 2002 | 02:59 AM
Darkness's Avatar
Darkness
Default Only one tire spins
I've noticed that only my right rear tire spins when I floor it on rights, but if do it on left turns both of them will spin, why the heck is this happening.
Paul
Old Jul 15, 2002 | 04:36 AM
Jvette73's Avatar
Jvette73
Default Re: Only one tire spins (inferno-vette)
Sounds like maybe the clutches in the limited slip diff are worn and a bit loose. All open(non-posi) diffs will usually spin the right wheel. When you floor it to the left, more weight is planted to the right tire, giving it more traction, then the left spins with it and around you go. What happens if you burn out straight?
Spinning wheels while turning, with a posi or limited slip diff, is especially hard on the clutch packs and spider gears.
[Modified by Jvette73, 2:37 AM 7/15/2002]
Old Jul 15, 2002 | 06:03 AM
Mikes80L48's Avatar
Mikes80L48
Dude you got any pics of your car? You did the exact same thing to your car that my dad wants to do to his.
Old Jul 15, 2002 | 04:12 PM
verskel's Avatar
verskel
Also, check your shocks.....one of 'em could be 'bad' allowing one side to have better (uneven) traction ! ;) :chevy
Old Jul 15, 2002 | 11:30 PM
dman535's Avatar
dman535
Default Re: Only one tire spins (verskel)
There were a limited number of C2/c3 Corvettes that were produced without posi-traction. I doubt on a later model C3 that its the case. Has someone been inside the rear end and swapped the carrier to an open diff ?
Old Jul 16, 2002 | 02:38 AM
88'Cubka's Avatar
88'Cubka
St. Jude Donor '08
k, this is a bit off topic hehehe
265/15 front and 295/15 rear
I was wondering, with the 295 rear tires, did you have to modify anything to make them fit? what about the 265 fronts? any rubbing or anything?
i was also wondering what profile you ran on front and back, 55's on the rear and 50's on the front?
thanks alot inferno
To Only one tire spins
