Newb help solving engine issue
Old Feb 26, 2014 | 10:29 AM
mijohnst's Avatar
mijohnst
Default Newb help solving engine issue
I've spend the last few months slowly working on my breaks so I haven't started my car in about 2 months. I learned a good lesson on leaving the key on for 2 months and it's effects on completely killing a good battery too.
Now i have the brakes done so I start the car and now it's just runs really rough and will stall almost every time I push the gas...even after it's good and warm. It sounds awful too. I put it in neutral and revved the engine to about 4k RPM and I can see it dip to 3.5k RPM intermittently. So what should I look at first? Gas filter? Carburetor adjustment? Distributor adjustment? I haven't worked on car engines since I was a teenager so I'm learning this stuff all over again. :/
I really appropriate this forums help!
Old Feb 26, 2014 | 10:34 AM
MrJlr's Avatar
MrJlr
Now i have the brakes done so I start the car and now it's just runs really rough and will stall almost every time I push the gas too hard even after it's good and warm. It sounds awful too. I put it in neutral and revved the engine to about 4k RPM and I can see it dip to 3.5k RPM intermittently. So what should I look at first? Gas filter? Carburetor adjustment? Distributor adjustment? I haven't worked on car engines since I was a teenager so I'm learning this stuff all over again. :/
Was it running good before ? If so, I'd start with the fuel system.
Points or HEI? Leaving the key on can burn points...
Old Feb 26, 2014 | 10:40 AM
Mashman's Avatar
Mashman
When you left the ignition on, if the points were closed, you would have fried the points, and possibly the ignition coil.
If you have a points replacement system, such as pertronix, it will have been fried also - I use the se-breakerless kit, and one of it's benefits is it doesn't get fried if you accidentaly leave the ignition on.
Old Feb 26, 2014 | 10:42 AM
MrJlr's Avatar
MrJlr
What year is the car?
Some more details would sure help
Old Feb 26, 2014 | 11:02 AM
my 76 ray's Avatar
my 76 ray
Two months shouldn't be long enough to cause problems with the carb if it was running good before. Leaving the ignition on for that long will fry points if that's what you have.
Old Feb 26, 2014 | 11:05 AM
mijohnst's Avatar
mijohnst
Oh, my bad... It's a 1976 L-48 with a 350.
I didn't know you could burn the points and the distributor up by doing that. Crap. I bet that's the problem because it ran fine before I killed the battery. I'm glad I mentioned the battery problem in this post. This is going to be fun figuring out how to change out points. Would this be a good time to switch out to a different type of distributor without points?
Old Feb 26, 2014 | 12:04 PM
Mashman's Avatar
Mashman
This is why you should always include the year of your car in the initial post - your 76 should not have a points distributor, in 75 the started using HEI distributors.
But, with the symptoms you described, maybe a previous owner switched back to a points distributor and coil. Do you have a seperate coil next to the distributor?
Old Feb 26, 2014 | 12:28 PM
MrJlr's Avatar
MrJlr
'76 never came with points ignition...no worry there.
It's either going to be a fuel or spark problem - this much is fact.
Old Feb 26, 2014 | 12:39 PM
Rich's'78's Avatar
Rich's'78
Default dead battery
Did you change out the battery with a new one yet? A dead battery can cause wild swings in electricals from my experience, but I don't understand why the alternator doesn't run things okay. Maybe shorting in the battery?
Old Feb 26, 2014 | 12:56 PM
MrJlr's Avatar
MrJlr
OP is MIA.......
Old Feb 26, 2014 | 04:35 PM
GreenDream's Avatar
GreenDream
Originally Posted by MrJlr
OP is MIA.......
He's out looking for the points he doesn't have...
Old Feb 26, 2014 | 04:45 PM
wisoutlaw's Avatar
wisoutlaw
This whole conversation is pretty pointless.
Old Feb 26, 2014 | 05:32 PM
mijohnst's Avatar
mijohnst
Sorry, I'm at work, so I have to post when I have a minute. I don't know exactly what I have so I'm going to go and look tonight.
I bought a new battery so hopefully that's not a problem. I'm going to go and take the distributor cap of tonight and I'll post a picture of what I see. Hopefully they'll help because I won't know what burned out points look like. Thanks again for the support!
Old Feb 26, 2014 | 05:39 PM
MrJlr's Avatar
MrJlr
Your '76 never had points, so I truly doubt it does now.
Start with some basics if it was running good before.
Clogged fuel filter?
Can you describe how it's running a little better?
Old Feb 26, 2014 | 07:05 PM
aussiejohn's Avatar
aussiejohn
Default Crossed wires???
I agree that the rough running engine could be caused by bad fuel or fouled plugs, but could also be caused by crossed plug wires.
First, pull out the plugs and clean them, then replace. Second, start with #1 spark plug and go around the engine in this sequence: 18436572.
Third, if the engine still runs roughly, you can pretty much assume that it's a fuel problem. Check the filter(s), then float level, even the flow from the fuel pump.
I doubt the HEI distributor is the problem, generally they either work properly or not at all.
Regards from Down Under.
aussiejohn
Old Feb 26, 2014 | 08:00 PM
diehrd's Avatar
diehrd
That gave me a chuckle ..
He could also just be flooded from pumping it to much and has yet to let it run long enough to clear it .
Old Feb 26, 2014 | 08:35 PM
ctuinstra's Avatar
ctuinstra
When he says it stalls almost every time he presses the gas, sure sounds like lack of fuel. I'd bet it's a carb issue or possibly fuel filter.
To Newb help solving engine issue
Old Feb 26, 2014 | 09:42 PM
mijohnst's Avatar
mijohnst
I can't tell the difference between points and HEI... So, in 1976, they didn't do points. I'd like to verify that. I'm going to go ahead and get a new distributor cap kit, plugs/wires and fuel filter. In the meantime, is this an HEI distributor?
Old Feb 26, 2014 | 09:47 PM
MrJlr's Avatar
MrJlr
Yeppers, hei
Old Feb 26, 2014 | 10:01 PM
mijohnst's Avatar
mijohnst
Great! Thank you! I'm on Corvette Central now. Any pitfalls I should be aware of before I replace anything? From what I read there is no adjustment.
