Oil pump
Old Jul 15, 2002 | 01:18 PM
del's Avatar
del
5th Gear
Default Oil pump
Has anyone replaced an oil pump on an L48 and how big a job is it?
Old Jul 15, 2002 | 01:26 PM
The Dude's Avatar
The Dude
Default Re: Oil pump (del)
Drop the steering. Drain the oil. Remove the oil pan. One bolt to remove oil pump. One bolt to install new oil pump. Clean gasket mating surfaces on pan and block. Install new gaskets. Install pan. Re-attach steering.
Old Jul 15, 2002 | 03:33 PM
Kingt's Avatar
Kingt
Default Re: Oil pump (The Dude)
You will also have to install an oil pick up tube to the oil pump. You'll need to buy or fabricate a tool to do this. I would not recommend trying to re-use the old one.
Old Jul 15, 2002 | 04:13 PM
dman535's Avatar
dman535
Default Re: Oil pump (Kingt)
If you go with a high volume pump you will need to replace the oil pump driveshaft as well.
I highly reccomend the fel-pro one piece oil pan gasket set. Its expensive but makes the job fool proof and relativley painless.
Old Jul 15, 2002 | 05:25 PM
Turbo-Jet's Avatar
Turbo-Jet
don't forget to prime the pump before startup
the 1-pc gasket is really nice
Old Jul 15, 2002 | 05:44 PM
del's Avatar
del
5th Gear
Is priming necessary?
Old Jul 15, 2002 | 05:45 PM
del's Avatar
del
5th Gear
Thanks!
Old Jul 15, 2002 | 05:46 PM
del's Avatar
del
5th Gear
Default Re: Oil pump (Turbo-Jet)
Any tips on how to prime?
Old Jul 15, 2002 | 08:29 PM
Turbo-Jet's Avatar
Turbo-Jet
submerse the pickup in some clean oil, and spin the driveshaft by hand until oil flows from outlet. if you pour some oil in the pump first, this should not too take long. if you don't prime the pump, you could damage engine bearings if they don't get any oil for a few seconds. good luck.
Old Jul 15, 2002 | 08:39 PM
oger's Avatar
oger
The pan will clear the exhaust? My 79 sure looks like you have to drop the exhaust to get the pan off.
Old Jul 16, 2002 | 12:51 AM
71coupe's Avatar
71coupe
Default Re: Oil pump (dman535)
Isn't that 1 piece gasket for the later blocks ('86 + 1 piece rear main seal) I can't find that gasket for the older 2 piece rear main seal motor
Old Jul 16, 2002 | 08:18 AM
dman535's Avatar
dman535
Default Re: Oil pump (71coupe)
check this link out :
http://store.summitracing.com/partdetail.asp?part=24968
Old Jul 16, 2002 | 07:28 PM
virtue4u's Avatar
virtue4u
Default Re: Oil pump (oger)
I didn't have any trouble clearing the exhaust, but I have duals. The trick is clearing the steering. Someone once posted that a certain position (I don't remember the exact position) of the balancer allows more room between the steering and crankshaft for removing the pan.
Old Jul 16, 2002 | 07:59 PM
Paul L's Avatar
Paul L
Fel-Pro #OS 34510 T one-piece oil pan set for GM V8 267, 305, 350 and 400; 1975 to 1985.
Old Jul 16, 2002 | 11:00 PM
Turbo-Jet's Avatar
Turbo-Jet
Default Re: Oil pump (virtue4u)
put the timing mark at very bottom
To Oil pump
