69 steering colum
Old Feb 27, 2014 | 08:40 PM
Sayfoo's Avatar
Sayfoo
Default 69 steering colum
My steering wheel will go in and out about 1/16". I've been having intermittet problems with the right turn signal not canceling and this seems to be the problem. If I push it away from me, it works. Pull it out and no worky. The column seems to be stationary, but the inner shaft moves. I can see it at the rag joint.
So, I'm thinking a bearing or ??
Think this is dangerous?
How to fix, or is it just something I should live with. I do not want to r&r and rebuild this column.
Old Feb 28, 2014 | 08:04 AM
Jim Shea's Avatar
Jim Shea
The only way the steering shaft should be able to move the 1/16 inch that you mention is for the upper bearing to move in and out of the turn signal switch housing.
This picture shows the housing and bearing assembly. The bearing should be a press fit into the housing then a thin cast lip on the housing is supposed to be "spun over" to retain the bearing permanently in the housing. If the bearing is still in decent condition you might be able to disassemble the upper end of your steering column and carefully epoxy the bearing case back into the housing. There also might be remnants of the housing lip that you might be able to pean over to help hold the bearing in place.
The correct procedure would be to pull the column from your car. Disassemble it so you can fully access the housing and bearing.
Here is the location of three papers on 1969-1976 standard Corvette steering column disassembly and repair.
http://jimshea.corvettefaq.com/?p=959
Also, these pics may be of some value. However, these pics show the later standard Corvette column with the dimmer switch and the upper bearing assembling from the instrument panel side rather than the driver side of the housing.
http://jimshea.corvettefaq.com/?p=964
Jim
Old Feb 28, 2014 | 02:12 PM
Sayfoo's Avatar
Sayfoo
Thanks, Jim.
I'll check this all out and try to fix it in the car first.
Side note to others. Many times when I want to work on this car, I reach in through the open window and pull on the steering wheel and push on the top of the rear tire to push/pull the car out of the gararge. Alot of rolling resistance, so it is pretty hard for 1 guy, and is probably why this bearing may be pulled out. I don't like to run the car for 30 seconds to just run it out because it gets a lot of water vapor in the exhaust system.
Sometimes you can't win. Strain a gut to push the car out to save the exhaust system and break the steering column.
Old Feb 28, 2014 | 03:43 PM
mysixtynine's Avatar
mysixtynine
Thanks, Jim.
My car was manual steering so I believe my upper bearing was obliterated due to all the heavy handing to just steer the car when not in motion.
Could the lower clamp on the bottom of the steering shaft be loose therefore allowing the shaft to move up and down in the column?
Old Feb 28, 2014 | 07:24 PM
Sayfoo's Avatar
Sayfoo
I'll check it out. Thanks.
Old Mar 1, 2014 | 06:54 AM
mysixtynine
Jim Shea is the absolute Authority on columns.
Might be helpful to have someone sit in the car and move the steering wheel in the directions that you indicate.
Then you go outside and look at the bottom of the steering column. I have seen this kind of play show up at the rag joint as well due to the rubber insulator getting soft or tearing.
I don't have a picture of the column shaft up at that bearing location behind where Jim was indicating. I just can't recall if there was a raised area on the shaft to prevent it from pulling through the bearing.
Jim might have a picture of the bare shaft at that location.
Old Mar 1, 2014 | 07:16 AM
Jim Shea's Avatar
Jim Shea
The steering column steering shaft is actually made in two pieces. The solid upper shaft (where the steering wheel attaches) and the lower tubular shaft (that extends out past the lower bearing and has a cast flange attached to it) are held in place by injected plastic up inside the strg column. The plastic shears and the two shafts are designed to slide over each other in a severe frontal collision. So from late 1969 through 1982 the lower end of the steering column steering shaft could actually be made to slide back into the lower bearing if you pried on the lower shaft and broke the plastic injection joint.
Corrosion through the years between the bare lower steering shaft and the lower bearing can pretty effectively "lock" the shaft and bearing together. In that case, the only way the upper shaft and steering wheel can move in and out would be if the plastic injection is sheared and the upper bearing can move in and out of the turn signal switch housing. It is the round wire rings on either side of the upper bearing in the column head that prevents the two piece steering shaft from moving.
Early 1969 columns did have a clamp on the lower steering shaft. However, that clamp was positioned with a gap of about 1/4 to 1/2 inch between it and the lower bearing. The clamp was part of the energy management (in a severe collision). The clamp really wasn't part of the design that normally kept the steering shaft in place.
Jim
Old Mar 1, 2014 | 10:00 PM
Sayfoo's Avatar
Sayfoo
I do have a early 69 with the clamp. I did adjust the clamp up against the lower bearing and this did remove some play. I then removed the steering wheel and looked at the bearing. It was loose in the housing. After removing the bearing and cleaning it, I greased it and epoxied it back into the housing. I peened the housing edge over slightly also. I'll let the epoxy cure for a while then reassemble.
With the bearing out, the upper shaft seems to bear towards 1 side of the housing. The installed bearing does center it. Would this signify a misalignment with the steering box?
I have the flange locking bolt and the clamp loose now and I will tighten them after the upper steering is all assembled. Is this the correct method?
Again, thanks all.
Old Mar 2, 2014 | 08:24 AM
Jim Shea's Avatar
Jim Shea
Again, thanks all.
Note the gap between the clamp and the lower bearing face. It should not make a difference when you tighten the clamp.
There is a slight design angle between the steering column and the steering gear. That in itself may cause the upper end of the steering shaft to appear to "tip" when the upper bearing is removed. Look at the flexible coupling. The stop pins should be central in the cutouts in the flange that is attached to the steering column shaft. Turn the steering wheel one quarter turn and recheck to make sure they are still central. If they are central, then you are good to go.
The stop pin in this picture is not particularly centered but it does have clearance on both sides.
Jim
Old Mar 3, 2014 | 11:22 PM
Sayfoo's Avatar
Sayfoo
I got it back together and it seems fine. Will road test it tomorow.
Jim, what purpose does the clamp serve?
To 69 steering colum
