68 Starter Wiring
The brown also connects to the same terminal and brings power to the fuse box.
The small purple (connects to the terminal closest to the block, and only has power with the key in start.
The yellow only gets power with the key in start.
The small black is the wiper and fan ground.
http://www.vetteprojects.com/bmv/mis...tte%201968.pdf
which caused me all kinds of problems until I corrected the "splices" and replaced the neutral-start safety switch....
That might not be your problem, but I wanted to let you know that it's possible.
under the right side down lo, you will find a ~6" battery cable connected from the engine block to the frame, on MY car it goes from inside the frame horn to the engine block at the engine mount, rear bolt, some guys say it goes to another point further back on the block, but it does NOT go to a oil pan bolt.... clean and polish all those spots, resecure and RTV.....
if no go we have to get into it, what you also need do is take that thin black wire to a secure ground, it is the ground for the wiper & blower motor, as well as the fan speed relay on/near the fender....
other than that, all the above sounds correct to me....
