This Engine Kit from Skip White is Calling My Name
What could I expect with my top end on this assembly? My Milodon oil pan is supposed to fit the SHIP 2-piece RMS block.
I know I will leave HP/TQ on the table but sounds like a GREAT base for a 406ci engine... essentially adding 53 ci over what I have with my .020" over, 34-year old block. I like that the SHP block is NEW and has 2-piece RMS.
Would I have to use different diameter roller lifters to fit the SHP lifter bores? I like the fact it has the stock dimensions on deck height (not a tall deck block).
Perhaps I should lower my sites to a (DART SHP based) 377-383 short block kitr.
SCAT nodular cast crank sounds like the $200 crank available from Summit. They will swap parts for a fee (ex. Scat forged crank).
6" SCAT pro comp extreme duty forged i-beam rods
King Rod & Main bearings.
So, a forged crank is probably another $300-400.
2000 rod bolts another $100.
I've sent my Q's about torque plates, assembly balancing, ring fitting, etc. to SW. Will advise.
I could just buy an assembled ZZ4 short block (keep coming back to that)...
The reason I am considering buying a kit is I want to know I'm getting all US components. Perhaps I need to make a list and get individual prices to build a DART SHP short block ready for my top-end pieces.
The assembled GMPP 383 short block for $3,800 (free shipping) from Jeg's with pan, plate, damper, timing cover, oil pump/pickup doesn't look like such a bad deal compared to that unassembled SW kit.
http://www.dartheads.com/products/sm...ck-forged.html
These guys got an internally balanced, fully forged, 400 with Dart SHP block marked "New" (4th one down) for $3595 assembled or $3395 unassembled.
http://www.ohiocrank.com/chev_sb_shortb.html
http://www.flatlanderracing.com/rota...400forged.html
CNCMotorsports has some good Callies, Mahle kits as well. I know a lot of guys that do truck pulling with BBC's pushing 1200+ HP that use them exclusively.
What's with that flex plate and balancer? With the big write-up about how great the flex plate is, why is it not SFI certified? There is no info on that generic balancer.
Why no actual part numbers for any of the parts so you know exactly what you are getting?
He advised me on parts selection for my engine build.
The list, and other info can be found by searching "406 build" in this section.
Look for the thread started by him.
Life and too much traveling have temporarily put the brakes on the build. Need to do some real minor work (fuel line) before getting it to the machine shop for run-in/ dyno.
Purchase of a project Porsche 911sc hasn't helped either. Hopefully by early summer we'll be ready for the R&R
Carter
It will probably be the assembled $3,800, ZZ383 short block. Forged crank, PM rods, with hyper pistons. Has the oil pan/pump/pickup, flex plate, damper and plastic timing cover. I would just add my steel timing cover (to clear my short water pump), gasket kit, new timing set, my roller kit and all top-end pieces, fuel pump, etc.
How are they vs the 2piece RMS as far as sealing and longevity is concerned?
