Drain the block
Old Mar 2, 2014 | 10:04 AM
79vetter's Avatar
79vetter
Default Drain the block
I'm running only water in my coolling system in order to t-shoot a pesky leak. Its about to get below freezing outside so I went to remove the plugs on the side of the block. I broke off my tool inside of the first plug
I was able to get the other plug on the other side of the block .
Is there another way of safely draining the block?
Old Mar 2, 2014 | 11:04 AM
redvetracr's Avatar
redvetracr
drill a small hole right through the pipe plug, just try not to electrocute yourself.
