TH400. Vacuum modulator line replacement.
Old Jul 15, 2002 | 04:31 PM
Stewart's74's Avatar
Stewart's74
Default TH400. Vacuum modulator line replacement.
Can I use a rubber Vac hose for this or do I need a metal line (as was originally) :confused:
Stew
Old Jul 15, 2002 | 04:51 PM
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
Default Re: TH400. Vacuum modulator line replacement. (Stewart's74)
A good rubber hose will do the job. It's just a vacuum line. :yesnod:
Old Jul 15, 2002 | 05:48 PM
NHvette's Avatar
NHvette
Default Re: TH400. Vacuum modulator line replacement. (gb4622)
Yeah, but why ??
Steel line costs about the same as rubber hose, and will last longer,
if painted (or cleared) before install. You should be able to get a length
of line from your parts store for cheap $.
less Bubba = more road time
To TH400. Vacuum modulator line replacement.
