power steering
Old Mar 4, 2014 | 11:06 AM
kyflyboy's Avatar
kyflyboy
Default power steering
1978-- pulls to right, but goes straight with engine off, any help steve
Old Mar 4, 2014 | 12:32 PM
MelWff's Avatar
MelWff
pulls to the right when going down a road with no crown? sounds like the power steering control valve needs to be adjusted assuming nothing else is wrong.
Old Mar 9, 2014 | 08:57 AM
kyflyboy's Avatar
kyflyboy
Default control valve
How does one adjust the steering control valve?
Old Mar 9, 2014 | 12:51 PM
my 76 ray's Avatar
my 76 ray
First, make sure that is the problem. Jack up the front and support it on jack stands. Then start the engine. If the wheel turns to the right by itself then you have found the problem and you need to adjust it.
Here's a video that shows how to adjust it. Since you are not replacing the valve you can adjust it with it connected and watching the wheels for movement. The video shows how to adjust it before connecting the rod. The adjustment procedure starts at 6:23 of the video.
To power steering
