C3 BBC Gearbox's
Old Mar 4, 2014 | 03:42 PM
roscobbc's Avatar
roscobbc
Default C3 BBC Gearbox's
Thinking long term about replacement of M21 on my 68' BB Vette. With a 'stroker' engine and 3.08 rear end the stock M21 ratio's work really well for me. Had the engine built with plenty of low end torque so some the 5 and 6 speed transmissions all seem to have an ultra low 1st gear which (for my car) would result in too much wheelspin and wasted motion. Ideal scenario would be something like a 5 speed with first 3 ratio's same as M21 but with perhaps a 50% to 70% overdrive 5th gear. Need to have TQ rating in excess of 600 ft/lbs. Considered a Gearvendors add-on overdrive, but the cost is close to a new gearbox - a 60's Hone unit would be a consideration but used units seem to be close to the new cost of a GV unit.
Old Mar 4, 2014 | 07:31 PM
Garys 68's Avatar
Garys 68
tko 600 with 2.87 1st, 0.64 5th? close enough?
T56 with 2.66 1st, 0.5 6th?
Old Mar 5, 2014 | 07:38 AM
Super6's Avatar
Super6
Anyone know the torque rating on the T56?
Old Mar 5, 2014 | 08:18 AM
69ttop502's Avatar
69ttop502
The Richmond Super Street 5 speed overdrive has a 600 ftlb rating and I believe a .77 overdrive 5th. With 3.08's I can't believe you even need an overdrive.
Bill
Old Mar 5, 2014 | 08:29 AM
zuendler's Avatar
zuendler
Have a TKO 600 with a zz502 and 3.70 rear end.
Don´t think the first gear is too low.
When your engine has more power, why don´t you just launch in 2nd?
Previously I had the M21 too, and the first gear was always to long to drive slowly with the car. Well this doesn´t matter if you use it only on the track and not in normal traffic.
Old Mar 5, 2014 | 08:37 AM
flyeri's Avatar
flyeri
I think you would be unhappy with a 3.08 and a TKO .64 OD. I have the .64 and 3.55 rear gear with a healthy big block. It runs 50 mph just above idle rpm. Check the ratio/speed/rpm calculator on American Powertrain site to see what you would be turning with your setup. You may opt for the .80 OD with that rear gear.
Old Mar 5, 2014 | 08:54 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Autogear sells an overdrive gearset for your Muncie with a .87 OD. M21Y
Old Mar 5, 2014 | 02:54 PM
roscobbc's Avatar
roscobbc
About 1000 rpm at 50mph?
Old Mar 5, 2014 | 03:01 PM
roscobbc's Avatar
roscobbc
Bill
70 mph with 3.08 and 27" tall tyres is 2500 rpm. 1500/1800 rpm would be a logical cruise rpm.
Old Mar 5, 2014 | 03:02 PM
roscobbc's Avatar
roscobbc
Yes I've noticed that - interesting idea
Old Mar 6, 2014 | 01:57 AM
Ibanez540r's Avatar
Ibanez540r
If your pushing that much power, is it worth it to put money into the original trans that is likely to eventually break anyway?
Old Mar 6, 2014 | 03:23 AM
roscobbc's Avatar
roscobbc
Good point - I have been running M21 with this combo for a few years and it has held together so far (although I am careful with it - so no 6000 rpm/clutch dropping drag starts!)
Old Mar 6, 2014 | 04:43 AM
zuendler's Avatar
zuendler
My zz502 broke the M21 after one year. So you are a lucky man
Old Mar 6, 2014 | 12:22 PM
v2racing's Avatar
v2racing
If your engine is that beefed up and has much cam in it, 1500/1800 RPM will be way below the efficient cruise RPM. 2500 RPM is not that high a cruise RPM for a large cam. What are the specs on this engine and the cam?
When I had the engine and trans in my signature in my 80 Vette with 3.07 gears, it ran best and got it's best mileage above 80 MPH.
Old Mar 6, 2014 | 02:01 PM
roscobbc's Avatar
roscobbc
489 - Brodix Race Rite Oval port - Edelbrock Air Gap - 950 DP - 10.5 c/r - 236/242 @ .050" hyd flat tappet - .550"/%.556" lift (can't remember rest of spec)
Old Mar 6, 2014 | 05:33 PM
63mako's Avatar
63mako
Leave it alone or go Richmond 5 speed with 1 to 1 5th gear. If you go with overdrive you will be below the operating range of your cam at highway speeds.
Old Mar 6, 2014 | 06:16 PM
roscobbc's Avatar
roscobbc
Ordinarily (and with my own past experience with other cars) I would agree with you - however with the dual plane inlet and relatively small oval port heads (for the engine capacity) port velocity I believe is quite high allowing good clean operation from 1500 rpm upwards.
Old Mar 6, 2014 | 08:44 PM
69ttop502's Avatar
69ttop502
I agree! Nothing worse than trying to run "below the cam" with all the bucking and jacking going on. I mean 1500-1800 is where the OEM 6 speeds run with way less cam. I like the the idea as well of tall rear gears and a 1 to 1 fifth. More efficient than overdrive. Nice car by the way.
Old Mar 6, 2014 | 10:58 PM
GRIZ73's Avatar
GRIZ73
Default C3 BBC gearbox
I have a 73 496 full roller with a rebuilt Muncie backed by a Gear Vendors Overdrive and 3:36 rear. Motor dynoed 632 hp. It runs like a rocket and the drive line is extremely solid. Overdrive in 2nd, 3rd, & 4th is awesome. I will probably switch to 3:55 or 3:73 sometime in the future to help take off with this motor.
I love the GVO and am doing it again on my new 73 BB project.
To C3 BBC Gearbox's
