M20 or M22 transmission length
Old Mar 6, 2014 | 12:30 PM
1980Guy's Avatar
1980Guy
Default M20 or M22 transmission length
My brother in law is doing a T56 swap on his '68. He has offered me one of two transmissions he has in the car: either the M22 that's in the car or an M20 wide ratio that he has as a spare. The deal will include the bell housing, clutch, flywheel and linkages. I will buy a new spring and plate, have the flywheel resurfaced and will rebuild whichever Trans I get.
My '80 currently has a TH350 with 3.73 rear end gears. I am leaning towards the M20 to give me a better too end and my motor makes ~420 at the crank so I doubt I will miss the lower gearing. If anyone disagrees please tell me.
My question is, how long are the Muncies compared to my Turbo? Will I have to have my drive shaft shortened or have a new one cut?
Old Mar 6, 2014 | 01:46 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I'm not completely certain driveshafts are all that much different, but you can look for the stock 1980 4 speed transmission driveshaft used on the L-48 cars.
Old Mar 6, 2014 | 02:23 PM
MIKE80's Avatar
MIKE80
I did a T56 swap on my 1980 4 speed and still have the original trans crossmember and driveshaft sitting in my garage. The driveshaft has the slip yoke with solid Spicer U joints and the crossmember was acid dipped and powdercoated red. If it turns out that they are something you need, PM me.
Old Mar 6, 2014 | 03:39 PM
joewill's Avatar
joewill
neither transmission will give you a better top end, 4th gear is straight thru and 1:1 ratio on both of them.
the m20 with it's lower 1st gear ( higher numerically ) will give you better torque multiplication in 1st gear.. the m22 will have 2nd and third gear closer together. you won't see as much rpm difference between gears.
Old Mar 6, 2014 | 05:05 PM
1980Guy's Avatar
1980Guy
Thanks guys. I knew about the 1:1 final drive. For some reason the way I was thinking about it I was operating under the impression that the M22 had some sort of underdrive final gear, even though I knew it didn't.
Easy Mike, that is a good idea.
Mike80, so I am correct in assuming then that the Muncies will NOT bolt up to my TH30 crossmember? Will I have problems mounting the other crossmember since my car is set up for a bolt on xmember and the manuals were weld-on? I might very well take you up on that offer. PM sent your way.
Old Mar 6, 2014 | 07:11 PM
keithl1967's Avatar
keithl1967
As far as your original question, I could be wrong, but my research so far indicates that a Muncie will be a direct bolt in replacement for the TH350...at least as far as size goes...
same cross member, same drive shaft, etc...
I can tell you, form experience with my other car on which I did the swap, that was the case--I do not see why it would be any different on the 'vette, either--the dimensions of the Muncie and TH350 do not change
Old Mar 8, 2014 | 11:47 AM
1980Guy's Avatar
1980Guy
The TH350 is the same length as the Muncie?
Old Mar 8, 2014 | 11:54 AM
keithl1967's Avatar
keithl1967
yes, including bellhousing, from back of engine to back of transmission, the tH350 is the same length as a muncie...
assuming it is a car TH350, and not a truck TH350 that has the long tailhousing...
Old Mar 8, 2014 | 06:39 PM
ironleg's Avatar
ironleg
Default M20/M22 vs TH350
In fact, the M20 with GM bell housing is a direct fit to the TH350, same lenght, output shaft splines count. A M22 shares same dimention lenght wise but output slines count is 32 like a TH400.
Hope this helped !
Old Mar 11, 2014 | 11:36 PM
1980Guy's Avatar
1980Guy
It did! So the M20 would be a more direct fit. The motor was designed based on the TH350 that is in the car. I do not believe that it is a truck 350. The cam on the motor gives me a very wide power band (~1500 - 5500, redlining at 6500). Would the wide ratio be the better choice for me then?
Old Mar 12, 2014 | 08:15 AM
keithl1967's Avatar
keithl1967
An M20 or an M21 would be a direct fit, with the same number of output splines.
As far as which would be better for you, it really depends on the rear gear you have. If you have the stock 3.08, I would go with the M20, which has a more stout 2.56 (or 2.52, depending upon the year of the trans) first gear (the M21 is a 2.20, if memory serves correctly). This means, you will have abetter "launch" off the line with the M20 and a stock gear.
If your rear is NUMERICALLY higher than 3.73 (ie 3.90 or 4.11), I would go with the M21...
In my '67 camaro, I have an M20 and a 3.73...it is really the "sweet spot" for taking off, but 1st gear is VERY short lived before having to shift...
Old Mar 17, 2014 | 11:01 PM
1980Guy's Avatar
1980Guy
Keith,
Mine is an L82 car. I want to say it has 3.73's for some reason but I can't back that up.
Old Mar 18, 2014 | 12:08 AM
keithl1967's Avatar
keithl1967
Keith,
A 3.73 could go with either an M21 or an M20....In my Camaro, I have the 3.73 and M20, and it is a great launch...
If the gear is numerically higher than 3.73 (ie 3.90, 4.10), then I would go with the M21...
You could always put the rear of the car up in the air (properly supported, but so both rear wheels can turn freely), and mark the tire. Spin it forward, and count the number of revolutions of the pinion yoke for one full tire revolution...just over 3= 3.08; 3 and 3/4turns =3.73, closer to 4 full turns, and your looking at 3.90's or 4.10, etc...
Old Mar 18, 2014 | 07:38 PM
ironleg's Avatar
ironleg
Default L82 m20
I had best results using M20 small block setup. In fact, starting 1967, L48 M20 was the hot ticket in the SS350 camaro Vette. L82 M20 is indeed a superb combination !
Good luck swaping
Old Mar 24, 2014 | 10:55 PM
1980Guy's Avatar
1980Guy
Iron,
Thanks! The close ratio is actually the M21. It looks like the M20 would be the easier swap but the M20 has been sitting for a good length of time with old fluid in it.
Old Mar 25, 2014 | 10:05 AM
Richard454's Avatar
Richard454
For clarification Muncies PRE 71 are ¾" SHORTER than the later ones....
Here's a good read- http://www.chevyhiperformance.com/te...swapping_tech/
Richard
To M20 or M22 transmission length
