who has 336 gears?
Old Jul 15, 2002 | 09:41 PM
LT1driver's Avatar
LT1driver
Default who has 336 gears?
what rpm do you turn at 70? I am considering this gear ration for my car. :D Thanks. :cheers:
Old Jul 15, 2002 | 09:47 PM
bence13_33's Avatar
bence13_33
Default Re: who has 336 gears? (LT1driver)
With 215/70/15 tires I turn 3000RPMs at 70mph. I have 3.36 gears. It's a pretty decent all around gear.
Old Jul 15, 2002 | 10:01 PM
Fevre's Avatar
Fevre
Default Re: who has 336 gears? (bence13_33)
Damn Shane that is one hell of an engine you built to run those times on a 3.36 gear. Slap a 3.55 or 3.7, some slicks and watch out!
I have a 3.7 and am getting a 5 speed because of it. The tranny swap will be about the same as a gear switch and give me a better range of final drive ratios then just a 4 speed and a lower gear.
Old Jul 15, 2002 | 10:06 PM
bence13_33's Avatar
bence13_33
Default Re: who has 336 gears? (Fevre)
Fevre:
That's what everyone keeps telling me. I'm actually considering going with a set of 4.10s to go along with my 4 speed. I'd really be cooking then :D.
Old Jul 15, 2002 | 10:19 PM
Robert N's Avatar
Robert N
The RPMS at 70 mph is subjective based on your tire size, rear gear ratio and final tranny ratio. I should 69 MPH at 3000 RPMs with 215/70R15s, 3.70 rear gears and an M21 in 4th gear (1:1). This is based on a calculation I have found that seems pretty accurate.
Bence - I might be wrong here (wife tells me that a lot :D ), but your speedo could be off, though I don't know the final drive gear ratio on your tranny.
LT1driver - you would be at 2763 RPMs at 70 with an M21 in 4th gear and the same tires with 3.36 gears, again if my calculations are correct.
[Modified by Robert N, 7:23 PM 7/15/2002]
[Modified by Robert N, 7:24 PM 7/15/2002]
Old Jul 15, 2002 | 10:25 PM
SteveG75's Avatar
SteveG75
Bence,
You need to buy FroDaddy's TKO. You get the steeper first gear plus the OD on the highway. I am cruising at 70mph at 2000 rpm and 3000 is about 105. Gotta a love that .68 OD 5th gear.
FYI, if you still have that T-10 and swap to the 4.10 rear:
2.64 x 4.10 = 10.82 overall first gear ratio
With the TKO and the 3.36's:
3.27 x 3.36 = 10.99 overall first gear
I think the BB could handle the larger RPM drops with the TKO. :smash:
[Modified by SteveG75, 8:27 PM 7/15/2002]
Old Jul 15, 2002 | 10:40 PM
bence13_33's Avatar
bence13_33
Default Re: who has 336 gears? (Robert N)
Robert:
http://www.smokemup.com/auto_math/mph_range2.php
My tranny is a T10 4 speed with a 1:1 4th gear. If you do the math on the website (215/70/15 tires = 26.85" tall tire). You get 70mph @ 3000RPMs. I've check the casting number of the rear end and it is indeed a 3.36 rear end.
Steve:
If I had the money man I would :). A complete rebuilt 4.10 rear end would cost 1/2 as much which would leave $1000 to put into the engine or whatnot :). My car doesn't see a lot of highway driving anyway.
Old Jul 15, 2002 | 10:41 PM
trw's Avatar
trw
I run about 2800-2900 at 70 with my 3.36's. I have 255-60's on the rear.
All four speeds M20, M21 and M22 are 1:1 4th gear ratio.
Terry
Old Jul 15, 2002 | 11:08 PM
Phlash's Avatar
Phlash
Default Re: who has 336 gears? (trw)
With 255/70/15's I run ~2800 @ 70. TH400 tranny with 1:1 out in drive.
Phlash 72 BB Roadster :seeya
Old Jul 15, 2002 | 11:28 PM
LT1driver's Avatar
LT1driver
Default Re: who has 336 gears? (Phlash)
Thanks guys, that is what I was looking for. Need the TKO with a first gear of less than 3.o one day in the future I hope. :cheers:
Old Jul 16, 2002 | 11:48 AM
Surfer69's Avatar
Surfer69
With 26" tires I'm at 3100 rpm at 70 mph and 3500 at 80.
To who has 336 gears?
