Question about side pipes and rocker panels
Old Mar 8, 2014 | 07:28 PM
havesometo's Avatar
havesometo
Default Question about side pipes and rocker panels
I'm in the process of installing side pipes on my 1980. And I need to know how the side pipes and rocker panels are installed?
Old Mar 9, 2014 | 10:39 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Since they're aftermarket, the manufacturer of your pipes should provide installation instructions. My guess would be the stock rocker panels would not be used behind the pipes.
Old Mar 9, 2014 | 11:31 AM
qwank's Avatar
qwank
I think you have to trim the moldings in the front to get them to work with the side pipes.
A doubt his pipes came with install instructions, the Chinese knockoffs never do.
Old Mar 9, 2014 | 12:41 PM
'75's Avatar
'75
My side pipes required no trimming of the rocker panels, your results may vary. The side pipe tubes have brackets that will bolt to the frame behind the panels using existing slotted holes. If the hardware is not included in your kit, you may have to get the bolt kit from Hooker, or fabricate your own.
Old Mar 9, 2014 | 01:27 PM
Super6's Avatar
Super6
Summit has hardware kits too.
I saw a good suggestion from someone here on CF for installing the trim pieces. Take the rear tire off, so you can slide the trim pieces in more or less parallel to the frame rails. I haven't tried it myself, I don't run trim pieces on mine.
Old Mar 9, 2014 | 03:50 PM
wabco40's Avatar
wabco40
The front of my panels required clearencing for the pipes.
They are installed by removing the rear wheels and sliding them in between the frame and side pipe.
Old Mar 9, 2014 | 08:24 PM
havesometo's Avatar
havesometo
I did get them installed I had to remove the rear tires and slide the in. I had to cut the passenger side front rocker panel. You can tell that I did it just by looking at it unless you know I did.
Old Mar 9, 2014 | 08:49 PM
T-TOP TOM's Avatar
T-TOP TOM
What brand of sidepipes do you have on yours and BB or SB? Thanks, Tom
Old Mar 9, 2014 | 09:01 PM
havesometo's Avatar
havesometo
Its a SB and the pipes are OBX.
Old Mar 9, 2014 | 09:53 PM
'75's Avatar
'75
I bought mine from the company that became obx back in 2008. It's a small block.
To Question about side pipes and rocker panels
