Brake lights help needed
Old Mar 8, 2014 | 10:14 PM
Oldguard 7's Avatar
Oldguard 7
Default Brake lights help needed
When I turn on the headlights and apply the brakes my LH brake light goes out. (they work properly along with the turn signals when the headlights are not on) Found out the ground in the socket was bad.
I replaced the socket and now the LH brake light stays on and the turn signal will not blink when the headlights are on. What could be the cause?
Old Mar 8, 2014 | 10:56 PM
wombvette's Avatar
wombvette
Originally you had a bad ground, now you probably have a badly wired socket, and a maybe a bad ground too.
Old Mar 9, 2014 | 08:19 AM
Oldguard 7's Avatar
Oldguard 7
Badly wired socket? How so? The brown wire lights the low filament (tail lights), yellow wire (brake light/turn signal), and black wire (ground) I doubt I got any of the three wires crossed. I will check to see if this is the case. Need I check the ground in the front? Other than those things I don't know what else will cause this problem.
Old Mar 9, 2014 | 12:51 PM
Oldguard 7's Avatar
Oldguard 7
Hmm..... 54 views and no replies except
three..... and two of them are mine.
Old Mar 9, 2014 | 02:08 PM
Peterbuilt's Avatar
Peterbuilt
Roger goes into how to test and the problems with the sockets.
http://forums.corvetteforum.com/c3-g...n-signals.html
Old Mar 9, 2014 | 08:00 PM
72LS1Vette's Avatar
72LS1Vette
It could turn out to be the turn signal switch. All of the tail-light wiring goes through it and if the switch is malfunctioning you can get all kinds of strange problems with the brake lights and turn signals.
I forget exactly the problem I had but it was something like a turn signal would work except if the brake pedal was depressed. There is a plastic piece inside the steering column that falls apart with age (mine did) plus the turn signal switch was loose-feeling and wouldn't self-cancel in one direction. I replaced the switch and the plastic part and everything was OK after that.
Rick B.
Old Mar 9, 2014 | 11:17 PM
wombvette's Avatar
wombvette
When I turn on the headlights and apply the brakes my LH brake light goes out. (they work properly along with the turn signals when the headlights are not on) Found out the ground in the socket was bad.?
Sounds like a reasonable conclusion. When the ground is bad the constant filament will light because it back feeds through the other filament to some other ground. When the brake is applied voltage is placed on the other filament and both lights go out.
Brake light stays on? All of the time?, when the HL are on? what?
Old Mar 14, 2014 | 09:43 PM
Oldguard 7's Avatar
Oldguard 7
After I replaced the socket, when the HL are on, the LH tail light (both) filaments are lit as if the brakes are applied nor does the LH tail light flash when the turn signal is used. the RH tail light functions properly.
To Brake lights help needed
