1973 Tilt/Tele Horn Issue
Old Mar 11, 2014 | 11:56 AM
MikeDs73's Avatar
MikeDs73
Default 1973 Tilt/Tele Horn Issue
Gents,
I replaced my standard steering column with a liberated tilt/tele from another 73. When I did, I ordered and installed new screws, shims and a horn contact because they were all a little rusty. The column had 3 shims and I reinstalled 3 new shims. My problem is when I bump the steering wheel too hard our pull the tlit lever and let the wheel pop up the horn blows. I'm thinking the new horn switch is a tad too sensitive and I should probably try another one but I wanted to see if anyone thought it might be something else. Thanks.
Old Mar 11, 2014 | 03:32 PM
jnb5101's Avatar
jnb5101
I had a similar problem. The after market horn contact was poorly made. I got a real GM contact and problem was solved.
Old Mar 11, 2014 | 03:35 PM
MikeDs73's Avatar
MikeDs73
Thats kinda what I was thinking. I guess I can't trust Eckler's. Where did you get the better one from?
Old Mar 11, 2014 | 07:22 PM
7t9l82's Avatar
7t9l82
mine, if i back up and turn the wheel hard the horn blows. haven't tried to diagnose it yet , but it should be fun. my colum is < 12k miles and un molested except i changed the key / switch
Old Mar 12, 2014 | 08:35 AM
jnb5101's Avatar
jnb5101
It's been quite a while, but I believe that I found an oem contact on the bay. I rebuilt another contact that was rusted and not making electrical contact by carefully disassembling and cleaning. If I remember correctly, one of the suppliers sells rebuild parts (the nylon bushings) needed.
Old Mar 12, 2014 | 09:21 AM
MikeDs73's Avatar
MikeDs73
Thanks. I'll look at going that route too then.
To 1973 Tilt/Tele Horn Issue
