I am installing ZZ4 in my 79 (4 speed) with Speed Demon carb. Question I have is about throttle cable bracket. Anyone have a solution to which bracket they have used that will work with this application? Thanx for the help. :seeya
I could take a picture tonight. It seems to me that I bought the standard Holley double pumper to GM bracket because I have my original 79 throttle cable.
I just took off my 825 Race Demon and went back to my old double pumper 750 speed demon because we have some 1/8 mile street drag races coming up. I'm trying to get instant throttle responce not max power in the 6500 - 7500 rpm range.
I went with the summit racing throttle bracket. This is the summit part number if you want to check it out. SUM-G1419 I took this bracket and drilled some closer holes into it to take the slack out of the cable.
I tried the Holley bracket, and to use I would have to drill a hole in the baseplate of the Demon, not sure if I want to do that. Do recall what PN you used? Will ck Summit also, thanx.....
