Typically a dual plane is for street and a single plane manifold is for the track. A single plane functions better at higher revs where it is used on the track and a dual plane functions better at lower revs usually giving better throttle response for the street.
Can anyone tell me pluses and minuses for both intakes?
And where is the best use for different intakes?
Thx,
John
Each intake should be matched to a combination of parts including gear ratio. You can use a single plane intake on the street, but your combination of parts would have to match and the manners might not be as suitable as the dual plane. What combination of parts are you asking for?
Reason: shittty spelling.
To add to this, my coupe already had a Torker 2 intake on it. This wouldn't have been my first choice for a street intake, but with the Holley carb (670 street avenger) and 4-speed manual transmission, I have to say I have learned to like it and it actually works quite well.
I'm assuming you picked the torqer due to rpm range and hold clearance? You could check out the wieand team g.
Actually I didn't pick it at all, it came already on the car! Along with the rebuild, carb etc. which was aready done. My point is changing the intake is farther down the list of things I am doing to the car, so in the meantime I am leaving it on and (at least with a 4-speed) it is doing a pretty decent job.
I am checking out the Weiand (and others!) since the drop down air cleaner on the car gives me a decent amount of clearance with the stock hood.
No offense, but the torquer isnth a very good intake. It makes sense since it came on the vette.
One more general question about single vs. dual plane intakes: does a single plane one typically provide more hood clearance? Or a double one? Or there is no such general rule? Thx all!
There's no general rule as it depends more on the specific design goals of each model intake. Most aftermarket intakes are designs for best performance within the design parameters, and that can dictate a lower or higher profile...but since aftermarket intakes are generally intended to perform better than factory models, they'll more often be higher in profile. That doesn't matter for the majority of applications, but for low clearance applications like Corvettes, it does tend to cut down the selection.
Saying that...I do believe that you'll find more dual-plane intakes being low profile than you will single-plane designs.
Generally, single plane intake manifolds are taller than dual plane intakes and would provide less hood clearance.
It's about runner length. Longer runners are intended for torque. Short runners are intended for HP. Dual planes have long runners and promote torque. Single planes have short runners and are more for HP.
Now with that said, a high rise dual plane on a 327 engine may be fine to say 6800 rpm. That same intake on a 427 may be fine till 5800. The same can be said about a single plane. A single plane on a 327 may be good to 7500 rpm and on a 427 CID it may be good to 6500 rpm.
What is important is matching the induction to the CID and rpm range of the intended engine.
I'll add that some intakes such as the Victor Jr. I have on my engine is a compromise. It has shorter runners for higher RPM power, but because of the low carb pad height the plenum volume is too small for my aplication. It fit under my 80 Vettes hood, which is what I needed, but the engine likes more plenum volume and picks up considerable power when spacers are added under the carb. Luckily my 75 Vert has an L88 hood I setup with the air chamber. I can add another 1 1/2" under the carb now and my engine will like that. The runners were too small for my heads on this manifold to start with so I had to do a lot of port work on the manifold. Even had to weld on it to be able to port it large enough.
It comes down to what Chris said about matching components of the build, which is something I have also preached forever.
Great info thanks Strabtech.
Very soon Kim will start up his 555 with the new cam. We all are looking forward to see/hear the result :- )
