Poly Bushings
Old Mar 20, 2014 | 07:33 AM
  #41
v2racing's Avatar
v2racing
Originally Posted by Mike Ward
Which describes 99.9% of owners, us included. I doubt there's less than .1% of people here who could detect bushing doing a blind test not knowing what type was installed. Never underestimate the placebo effect.
Did you know that 90% of all statistics are just made up on the spot?
If I couldn't feel every tiny thing going on when racing my Top Fuel bike, I probably wouldn't still be here today.
You can't just say nobody can tell the difference because I can't!
I believe the reason a lot people say there car rides harsher with poly is they put on stiffer springs, shocks, and bars at the same time. My 64 SS is anything but harsh and it did tighten up the steering on that big barge.
Old Mar 20, 2014 | 08:28 AM
  #42
MIKE80's Avatar
MIKE80
I guess the most amusing thing is people pretending that they're a good enough driver pushing their car hard enough to detect minor variations in bushing compliance. Kinda like a calibrated butt dyno for those bolt on 5HP increases.
Many years ago when I was much younger, living in rural farming areas, with less cars and police on the roads, we had old muscle, Trans AM/ Chevelle/ Camaro/ Mustangs/etc. and used to do a lot of street racing. With that, I was in quite a few police chases, once even being arrested for eluding. Back then the cops were pretty cool and I just ended up with a couple tickets and was released, not something you can do nowadays. So I would say "Yes, I pushed my cars REALLY HARD and can tell a difference in changes I made".
Now, I look forward to some occasional track days with my vette after I finish a little more work to it.
Old Mar 20, 2014 | 08:39 AM
  #43
78SilverCam's Avatar
78SilverCam
Originally Posted by Jim78SA
So, I was reading a thread and someone stated not to use the poly bushings for the suspension. He said everyone hated them. I was wondering why? I was thinking about doing this, but now I may be rethinking it? Are they bad, or is it personal choice?
Back to the subject:
Rubber has lasted on my car for 36 years. You don't put poly in some spots on the suspension (trailing arms). Rubber can go everywhere. Rubber is cheaper than poly.
I am rebuilding the suspension with rubber.
Old Mar 20, 2014 | 10:19 AM
  #44
gkull's Avatar
gkull
Sorry, I'm not following.
With rubber bushings there are no sliding joints or surfaces. The a-arm, bushing and shaft are all bonded together with only the flex of the rubber permitting any relative motion.
You actually believe the the bonded rubber in this bushing has the ability to stretch over 90 degrees?
http://www.vbandp.com/auto-parts.htm...yword=bushings
Old Mar 20, 2014 | 10:35 AM
  #45
Mike Ward's Avatar
Mike Ward
I guess that means you believe there is some metal on metal movement somewhere.
Where?
Old Mar 20, 2014 | 01:16 PM
  #46
gkull's Avatar
gkull
The inner metal tube on the rod.
Old Mar 20, 2014 | 01:51 PM
  #47
Mike Ward's Avatar
Mike Ward
Nope, sorry. That's incorrect. The inner tube is rigidly held in place by the bolt and washer. Some bushings have a serration on the end surface and a matching serration on the inside of the washer to ensure their is no movement. This is why a car must be sitting on it's wheels before the suspensions bolts/nuts are tightened.
http://www.import-car.com/Article/73...omplaints.aspx
"To eliminate wearing surfaces, the rubber bushing is bonded to inner and outer metal sleeves. The outer sleeve is usually pressed into the control arm or spring while the inner sleeve is clamped to the frame by a retainer bolt."
http://www.pistonheads.com/gassing/t...+arm+bushes%3F
A poly bushing, because of it's inability to flex or compress must be allowed to rotate across a mating surface, which is where the clearance, movement and wear comes from.
Old Mar 20, 2014 | 02:04 PM
  #48
pauldana's Avatar
pauldana
MW is correct:-) omg,
but Poly still do handle tighter, and yes i can tell, i have 4 vettes and i race them at the track... I can see the desire in rubber... and if you do NOT race, i think the rubber is better...
Old Mar 20, 2014 | 02:56 PM
  #49
cv67's Avatar
cv67
St. Jude Donor '05
In certain cases rubber can help prevent suspension binding.
I simply dont trust any rubber product made today to last like the originals so polygraphite it is.
Hell my rubber body bushings are only two yrs old anc cracking already.
Old Mar 20, 2014 | 03:12 PM
  #50
gkull's Avatar
gkull
Now wonder my car is so screwed up I didn't assemble it like an import car!
I was changing springs out a few years ago and I had a set of lower Rubber bushings and my poly were years old so I thought what the heck I'm already here and I wanted to media blast my a-arms and paint them anyway.
I did not assemble these on the ground. 600# QA-1 semi coil overs
[/URL]
Old Mar 25, 2014 | 01:34 AM
  #51
Panman's Avatar
Panman
Cruising
I am in the market to change the bushings, because I am noticing the rubber ones are dry rotted and are going to need changing soon anyway. I will probably go with the poly, because as others have stated, I like the firm, tighter ride.
Jim78SA - I would love to hear your decision results, how the install went and what you think of the new handling. My next project is the front end on my 81. It is loose, drifting and pulling after years of sitting and rotting. So your project is of keen interest as I have been looking at poly vs. rubber and can't see a reason to NOT do poly even though I want a daily driver... I want it tight like a sports car should be. Thanks in advance.
Old Mar 25, 2014 | 09:13 PM
  #52
Jim78SA's Avatar
Jim78SA
Panman, I will probably be doing this, this coming fall. I have my interior and engine bay to button up before the car show season.
Old Mar 26, 2014 | 02:24 PM
  #53
Wig's Avatar
Wig
Default Loctite
Originally Posted by hugie82
I can only speak for the front end bushings and I have no complaints!!! It's solid, smooth and no squeaks at all!
The only complaint I've heard was the upper control arm bushings working the bolts loose.... I loctite mine without any problems!
Did you use the red or blue?
Old Mar 26, 2014 | 05:01 PM
  #54
Patro46's Avatar
Patro46
Wow... opinions for each day of the week. Gotta love it. Here is mine. I needed to replace the 40 year old rubber in my 74 convertible one way or another. I chose poly, pretty much deciding on the difference between a loaded bushing and an unloaded bushing as being the basis for change. More accurately, a loaded RUBBER bushing. I may have a 1/2" ID in the bushing, but when loaded it looks more like an egg. This "egg effect" is transmitted into my steering, effecting things like handling and tire contact here and there. The camber is undoubtedly effected, and done so because of bushing load. You create this load in cornering BTW. And I like to corner... When camber changes while cornering, I lose traction due to poor tire contact. Deflection Steering is another issue present using rubber bushings, but that's another subject altogether. On our Vettes, these issues can effect BOTH the front AND rear in terms of handling. Will you notice the difference driving to the grocery store or to the monthly Vette meet?? Probably not. But if your carving your way through the back hills in Spavinaw or slingshotting your way through the Kiamichi Mountains, I don't know about you, but I want to KNOW I have the best possible tire contact on the road at all times, ESPECIALLY during cornering. My odds of this happening are far greater with Poly-graphite bushings than they ever will be with rubber. Feel free to hate me. Will some comfort be sacrificed? Yes. I Still have to steal from Peter to pay Paul... But it's a tradeoff I was willing to make. I think if most will spend a little time doing research on the pros and cons of Graphite vs Rubber, they will have enough information to make an educated decision based upon their own personal needs. Personally, I see green grass on both sides of the field. In a daily driver car or truck, given the option, I'd probably stay with rubber, for the sheer comfort and help in silencing road noise. But if I'm driving something where I tend to push the proverbial envelope, it's Polygraphite all the way.
Old Mar 26, 2014 | 05:22 PM
  #55
CraigH's Avatar
CraigH
Always discussion that brings up the extremes.
Mike is correct many people would not be able to tell the difference or even care.
However if you are an enthusiastic driver and like the tighter feel of poly go with it.
I have a poly through my front end and my mate has rubber.
He has observed the difference in overall tightness that it exhibits between the two cars.
Living on the other side of the world we have always considered US cars (a generalization) as worse handling in comparison to European models. Australian ones lent more to europe in suspension feel and tightness (you may call it harshness). So anything we can do to tighten up the vette is a good route to take.
So if you like the tighter feel as I said make that choice if not stay rubber.
We do however both also drive modified later model cars with suspension mods etc so possibly we should be categorized out of the decision equation as boy racers. :-)
Old Mar 28, 2014 | 12:34 AM
  #56
leskinner's Avatar
leskinner
When I rebuilt my 75 convertible I used all rubber bushings. I figured that when the GM engineers designed the suspension system on these cars they probably took the compliance of rubber bushings into consideration. Those guys are a lot smarter than me. Wouldn't adding the "stiffness" of poly tend to maybe move some stress to locations possibly not designed to handle it? Just wonderin'.....
Larry
Old Mar 28, 2014 | 07:44 AM
  #57
jb78L-82's Avatar
jb78L-82
Larry
There are many items, suspension and engine components, that were just not available when the C3 suspension was designed and actually being built from 1963-1982 that were just not available back then-one of them poly bushings. Others examples are stronger rear strut rods with heim joint ends, synthetic fluids, better tire technology etc. You get folks who say don't use a synthetic diff fluid because Eaton never recommended it back then. Well, synthetics were not around............does not mean it is not better now.
To Poly Bushings
Old Mar 28, 2014 | 09:00 AM
  #58
hugie82's Avatar
hugie82
I ordered black. I didn't want to attract attention to the original 100k + miles of road dirt under my car
Poly does clean up well because the dirt and grease doesn't soak in like rubber.
Let me add one more thing to this debate.
When a rubber bushing begins to fail. It is a major project to replace it.
When poly begins to fail. You can pop them out with your fingers and grease then replace in less than 5 minutes once the bushing is exposed.
Old Mar 28, 2014 | 10:07 AM
  #59
bballboy06's Avatar
bballboy06
looking for just the rear end poly bushing, has anyone found a kit for this?
thanks
Old Mar 28, 2014 | 11:06 AM
  #60
leskinner's Avatar
leskinner
I totally agree, new stuff is probably better.....however.....if you are still working with old, original, as designed components I still wonder what old components are suffering new stresses they weren't designed for.
