Setting timing... Car warm or does it matter?
Old Jul 16, 2002 | 04:19 PM
im181owner's Avatar
im181owner
Default Setting timing... Car warm or does it matter?
I have found the info I was looking for to set my timing, but was wondering does it matter if the car is cold/warm/hot?
Thanks!!!!
Old Jul 16, 2002 | 04:24 PM
Turbo-Jet's Avatar
Turbo-Jet
Default Re: Setting timing... Car warm or does it matter? (im181owner)
all engine tuning should be done when engine is at normal operating temp, ie: hot. (except choke). good luck
VettePower's Avatar
VettePower
Car should be at full operating temperature. :yesnod:
Old Jul 16, 2002 | 10:08 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
If you're doing a normal initial adjustment with the vacuum advance disconnected, it doesn't matter as long as the idle is where it's supposed to be. If you're doing a total setting, the idle speed doesn't matter. Timing is adjusted by changing the relationship of the distributor cap's contacts to the rotor's contact and that relationship is not affected by temp.
To Setting timing... Car warm or does it matter?
