Any one using block hugger style headers? I,ve had bad experiences with full size equal length tube headers (ground clearence, installation, cracking/loosening, etc...)
I think I remember someone mentioning in a similar thread that the c-4 manifolds bolt right in and flow better than the rams horns we have. Seems I even saw and engine pic with them on a c-3 engine. I am sure they will bolt on but not sure if they will bolt right to your/our exhaust pipes.
Geoff1340
I have a good one on my work pc. I go back to work Fri. It is the engine on a stand. I will email it to you Friday. I can't find any that really show them good on my home pc.
I've been told that there may be slight clearance issues with c4 tubular exhaust manifolds - these being at the idler arm and steering box - I bought a set for putting on my car - but eventually went with full length hedmans.
The pair I have are from a 85 I believe - they will bolt directly on - I cant speak to clearance issues.
