Tremic 5 speed oil
Old Mar 18, 2014 | 02:07 PM
1969RAY's Avatar
1969RAY
2025 C2 of the Year ('63 and '67) Finalist - Unmodified
C2 of Year Finalist (appearance mods) 2019
Default Tremic 5 speed oil
I would like to know the best oil for a Tremic 5 speed.
I used automatic transmission fluid as recommended when it was originally installed. What is the current recommendation for these transmissions? How often should it be changed for the occasional weekend driver?
Old Mar 18, 2014 | 05:02 PM
FKING1's Avatar
FKING1
They recommend GM Syncromesh.
I use Penzoil Syncromesh in mine that was recommended as a cheaper alternative by one of Kesler's techs.
Don't know about change interval.
Old Mar 18, 2014 | 08:13 PM
Black_Magic's Avatar
Black_Magic
2020 Corvette of the Year (appearance mods)
C2 of Year Winner (appearance mods) 2019
CI 4-5-7-9-10-11 Car Show Winner
CI 2-3-4-5-6-7-9-10-11 Vet
I switched to RED LINE in my '65 a few years back and notice much easier/smoother shifting.
Last week I switched to RED LINE in the '79 and also notice a difference.
Both have Tremec 5 Speeds.
George
RED LINE ATF -- D4
Old Mar 18, 2014 | 08:32 PM
BB2B's Avatar
BB2B
I used GM synchromesh at $18 per quart. recommended change is every 30,000 miles
Old Mar 18, 2014 | 09:49 PM
drwet's Avatar
drwet
I got my Tremec TKO 600 from Modern Driveline and they supplied Amsoil Synchromesh Transmission fluid with it. Haven't had a chance to drive it more than up and down the driveway yet so not much to report there. I'm not a big Amsoil fan but I figure I better use what they recommend.
Old Mar 19, 2014 | 08:45 AM
Solid LT1's Avatar
Solid LT1
Royal Purple or Amsoil in my TKO/T56 transmissions
Old Mar 19, 2014 | 09:20 AM
zuendler's Avatar
zuendler
Hurst wrote also Synchromesh and additional options would be ATF and a Mobil 1 transmission fluid.
They explained in the instructions, that oil that makes shifting easier causes more wear on the tension rings. So its on your own. If you want longer lifetime of the rings, you have to accept harder shifting. The Synchromesh would be the best between shiftability and tension ring wear.
Old Mar 20, 2014 | 08:07 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Note that the TKO primary fluid is a synchromesh (optional is ATF). This is the AMSOIL primary recommendation:
AMSOIL Synthetic Synchromesh Transmission Fluid (MTF) (Product Code MTFQT)
And the T56 primary fluid is an ATF. This is the AMSOIL primary recommendation (which is what I use in my T56 at the track):
AMSOIL Torque-Drive Synthetic Automatic Transmission Fluid (Product Code ATD1G)
More than happy to get AMSOIL products for forum members at dealer wholesale pricing, about 25% below retail, via the AMSOIL Preferred Customer Program. Drop me a PM if interested.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
To Tremic 5 speed oil
