is it the tranny?
Old Apr 9, 2014 | 12:01 PM
  #41
pleasants9's Avatar
pleasants9
where do you get the chip from and where does it plug in on my car?
Old Apr 9, 2014 | 02:29 PM
  #42
hugie82's Avatar
hugie82
Corvette Central.com part # 303016 for $139.95
Hypertech chip stage 1
It takes 5 minutes to disconnect the battery. ECM is located inside the rear compartment. Remove the plastic tray. Takes a little wiggling but it slips out. The ECM is screwed to the bulkhead between the seat and the compartment. Remove the little trap door on the ECM . Pull the prom and push in the new one.
When you finish, it drives totally different. You'll know it just pulling out of the driveway.
Old Apr 9, 2014 | 09:00 PM
  #43
maverickmk's Avatar
maverickmk
Originally Posted by TimAT
Someone referenced unplugging the lockup convertor-- sure fire way to kill a 700-R4. When the convertor locks up, the cooler line pressure jumps dramatically- forcing the fluid to cool thru the radiator. OK for a short term test, but leaving it disabled will cook the trans.
I thought the electrical connector was what made it lock up - no?
