Another grinding noise help wanted post
Old Mar 20, 2014 | 06:39 PM
Ranger24's Avatar
Ranger24
Default Another grinding noise help wanted post
Sorry if this has been covered but my searches have not given me anything that's similar. Lot of issues when cars are in gear but in my case I have a grinding or screeching noise when the clutch peddle is depressed. Once I put it in gear and engage the clutch the noise goes away. This occurs at a stand still and not everytime. e.g. if I'm in neutral and let the clutch out the noise will cease.
Thoughts on the problem??
Old Mar 20, 2014 | 06:56 PM
Phil Zell's Avatar
Phil Zell
throw out bearing would be my guess.
Old Mar 20, 2014 | 09:05 PM
Ranger24's Avatar
Ranger24
Wouldn't that make noise when the car is in gear also?
Old Mar 21, 2014 | 01:32 AM
wombvette's Avatar
wombvette
Throw out bearing works only when the clutch is depressed. Thats when it makes the noise.
Old Mar 21, 2014 | 07:58 AM
Ranger24's Avatar
Ranger24
Ok, I was afraid of that. Good to know what the problem is but another matter to fix it.
Thank you both for your inputs, much appreciated.
To Another grinding noise help wanted post
