Increasing HP in L82
but I know that a new cam and some new heads would make a difference. Anyone got any knowledge/ experience/ prices on anything about this?
Going beyond that, the $$/hp goes up, but it depends on your goals from there. I think an L-82 with a nice exhaust system and a well setup ignition and carb would be making close to 300. Beyond that and you're going to have to start opening stuff up - which is pandora's box, in a way.
IMHO
Definite seat of pants improvement.
this is exactly what i did on my 78 l82 manual and you don't believe the difference. (If you are alowed take the cat and pump air out too). After that made ,if you want more power get prepared to spend lot of money opening the engine
https://www.corvetteforum.com/forums...-my-plans.html
I found the Danger Mouse series of articles from SuperChevy very helpful.
but I know that a new cam and some new heads would make a difference. Anyone got any knowledge/ experience/ prices on anything about this?The L-82's are held back because of low compression and a weak camshaft. Increase the compression ratio to at least 10 to 1 and install a camshaft with about 230 to 235 degrees duration. Then to really make it haul install a TH700R4 and a set of 3.73's to give you awesome acceleration while maintaining a low cruising rpm.
but I know that a new cam and some new heads would make a difference. Anyone got any knowledge/ experience/ prices on anything about this?After that your next easy upgrades to consider would be something like an Edelbrock Performer intake... that will get you maybe 5-10 HP over the original L82 aluminum intake. Going to 1.6 ratio roller tip rockers will get you another 5-10 HP without changing heads or cam...
But you are right the heads and cam are really where you are going to get the most increases. You need to do both because the L82 heads and cam pretty much maximize each other so doing only one or the other won't buy you nearly as much as upgrading both... What you probably want is a good set of aluminum heads with 64cc chambers, 180cc intake ports and 2.02" intake/1.6" exhaust valves. Combine that with a moderate hydraulic roller cam, retrofit (link bar) roller lifters, roller tip rocker arms and a double roller timing set and you should get 30-50HP increase between the heads and cam setup. The aluminum heads will also drop your weight by 30 lbs or so, which doesn't sound like a lot, but the traditional rule of thumb is every 100 lbs weight savings drops around a tenth of a second off 1/4 mile time which is approximately the same as adding 10 HP.
For the ignition side you will probably want to put in a stronger coil in and maybe upgrade the module in the HEI and some high performance wires.
Anyway, all that together with a good tuning ought to get you close if not into the HP range ballpark you want...
The suggestion of a TH700R4 (or TH200-4R) transmission upgrade along with going to 3.42 or 3.73 rear gears is also excellent... Those mods will really improve your launch and still not kill you on cruising speed.
You will be quite happy
Whats sad is someone will probably believe this laughable nonsense
I'm all for someone putting some headers and better exhaust on there car if they want some more power but lets not go to silly hard sell laughable BS like this to convince someone.
It sounds like "pipe dream" and for all of you youngsters who don't know what a "pipe dream" is its what people do when they're smoking an opium pipe................hence a "pipe dream". Its an old 1900's term that was popular until the 1960's and 1970's when stronger drugs hit the streets.
My '82 ran 8 second flat 0-60's and it took a set of 3.73's, 10 to 1 compression, and a cam change to hit the 6 second flat mark. Timing and headers alone won't even come close to dropping 2 full seconds off a 0-60 time.
D'oh! Just realized I responded to a year-old post, wonder what the op decided?
