Tach Board croaked while driving. ( wilcox )
Old Mar 23, 2014 | 02:29 PM
Tin_Can_Terminator's Avatar
Tin_Can_Terminator
Default Tach Board croaked while driving. ( wilcox )
I was driving my car yesterday and the Tach needle instantly dives from idle speed ( 700-800 RPM ) to being pinned in the negative direction.
Now, whenever I turn the key on ( not starting the engine ) the needle gets pinned in the wrong direction instead of settling @ zero.
I have a Wilcox Board installed. ( installed Nov of 13 ) I don't drive the car a ton so there is maybe 1-2 hours on the board.
TCT
Old Mar 23, 2014 | 02:50 PM
confab's Avatar
confab
You contact him?
He seems very nice..
Old Mar 23, 2014 | 02:57 PM
Tin_Can_Terminator
I haven't contacted him yet. Its Sunday and this only happened yesterday. Plus he seems to respond quicker here than via email or phone. This isn't the first battle with this circuit board. And yes, he is very nice. :-)
TCT
Old Mar 25, 2014 | 07:59 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Glad its a 78-82 car, much easier to get at. If you ever need me, email me direct at support@Willcoxcorvette.com You'll get a generic message back but I'll answer you as quickly as possible.
Some people don't realize that you can pull the lens, then the speedo tach bezel and remove the tach without removing the entire housing so if you know this great, if you don't I have instructions on the web site to help you. http://willcoxcorvette.com/repairand...lp.php?hID=290
I would pull the tach, back off and then re-tighten the nuts holding the board in place.
One may be loose causing one side of the board to work only.
If that fails, send the entire tach to me and we'll take a look at it.
Willcox
Old Mar 28, 2014 | 04:01 PM
Tin_Can_Terminator
I will give this a try this weekend. I will let you know what I find out.
TCT
Old Mar 29, 2014 | 03:15 PM
Tin_Can_Terminator
Did as instructed. No change. I will contact you directly.
TCT
To Tach Board croaked while driving. ( wilcox )
