GEN Light always on
Old Mar 25, 2014 | 09:01 AM
bballboy06's Avatar
bballboy06
Default GEN Light always on
My gen light in my 79 wont go off
i check the alternator and it is functioning properly.
checked the connection to the alternator and it seems to be tights.
what am i missing?
thanks
Old Mar 25, 2014 | 09:08 AM
Aussie79's Avatar
Aussie79
what am i missing?
thanks
LOL, mine has been on since 1996, it still charges perfectly so I just ignore it, pretty common apparently. If anyone knows the fix I would be interested though, only because I get tired of every passenger alerting me to the Gen light like I cant see it.
Old Mar 25, 2014 | 09:56 AM
addballer696's Avatar
addballer696
im in the same boat, mine get brighter as the rpms increase. Put some electrical tape over the light which helps when its dark out
Old Mar 25, 2014 | 12:00 PM
lvmyvt76's Avatar
lvmyvt76
there is no generator light because you don't have a generator on the car.
It's probably a bad diode in the alternator causing this. It may still charge correctly, but it might start causing the battery to go down when not driven. The alternator can be rebuild easily and at a small price. Brushes and diodes are fairly cheap.
Old Mar 26, 2014 | 08:25 AM
keithl1967's Avatar
keithl1967
Same issue on my '77...have not gotten into it yet this year...
I already replaced the alternator with abrand new powermaster--light is still on...
Old Mar 26, 2014 | 09:55 AM
mrvette's Avatar
mrvette
Most likely cause is the two wired at the regulator, on back side of the alternator, are reversed.....with key off, engine still, when looking at the backside of the alternator, the whit two pin plug....-- arrangement....the one that is MOST CLOCKWISE is sometimes RED if the plug has been replaced, and the stock wiring is tough to tell the colors on as it gets old,.....now the MOST clockwise wire above should have a steady 12 volts on it, and the other one should not, when you turn on the switch without running engine, BOTH should have 12 volts on them,
if reversed, the switched voltage to one side of your red dash light passes through the bulb, and goes to the regulator at the LEAST clockwise point.....what happens is if the alt ceases to put out, the regulator will ground that wire, causing the dash light to light, but IF the wires are reversed, it's feeding the regulator sense wire and causing the light to light at least a bit.....
Old Mar 26, 2014 | 10:02 AM
MelWff's Avatar
MelWff
The other thought is similar to mrvette, that same two wire plug. Corrosion on the contact, a wire broken inside the insulation,etc. Using a sharp pointed test light you have to check the voltage at those two wires.
To GEN Light always on
