Showing my ignorance again here, but I'm trying to learn.
I've had my 75 for several years now, but I just had a 383 built that will be finished this week. It will be in the neighborhood of 430 horsepower, but I don't have any of the specifications in front of me.
The engine builder recommends a Holley 750 double pumper.
I went to purchase a Holley 750 and didn't realize there were that many models. Vacuum secondaries, mechanical secondaries, electric choke, manual choke ect. I admittedly don't know much about all of these things. I learn as I go.
My question is which model do I want/need and an even bigger question why do I want/need that one? I'd like to learn why instead of just saying cause that's what someone told me lol. Thanks in advance for any help.
The Holley 750 double pumper is a mechanical secondary carburetor. I would assume you would want an automatic electric choke. The carburetor below might be a good choice but you dont mention what type of transmission or rear end gears which factor in choosing the correct carburetor. You also dont mention what the projected redline of your engine will be. I arrived at this carburetor by using the carburetor selection screen at the Holley site, link below.
Right now the existing engine has an edelbrock performer with a holley 670 street avenger. I'm swapping to a performer rpm. Some say I will have to change the hood some say I will not with the right drop base, I will deal with that when I get there.
As of right now I'm almost certain it has the stock gear ratio of 3.08. Gears will be changed sometime in the next year.
I'm dropping the new engine in over the next month as I get time and it will immediately go to the transmission shop. It has a th400 which will be rebuilt and the engine builder recommends a stall of 2600 to 3000.
Thanks for the link to the carb selector. It doesn't suggest using the double pumper with the gear ratio I currently have. What will the downside be of going ahead and buying and using the 750 double pumper for now and changing gears later?
I think the carb you already have would work very well. No need for a new one.
Scott
The existing carb has issues and will have to be rebuilt or replaced either way. From reading it seems 670 will the on the low end of what I need? Is that your thought? I don't mind spending money to get the correct carb, I've had this car too long time to start fixing her up good!
So, rebuild it. You might get a few more horses with a bigger carb, but your 670 will be a great compromise street carb, with plenty of throttle response. What are you looking for; a big dyno number to brag about, or a car that's fun to drive?
Scott
Shooting for middle ground, I'd like to eventually start drag racing the car. Still have gears, half shafts and some of the suspension to do after the engine and transmission. But I'd also like it to be a streetable car. Probably one of those be really good at one or the other or ok at both? Thanks
If you are going to have an engine capable of 6,500 RPM, and will have a high stall speed because of a cam selection the builder is making, and you realize nothing will work as intended with the 3:08 you can go for the 750 DP.
