72 Base 350 Rebuild?
Dad says the base 350/200hp engine ran fine when he bought it, but that was 24 years ago and it has sat the entire time since. So far all I've done is pulled off the stock manifolds, carb, and intake manifold. Sucked some grain shells out of one of the exhaust ports, but otherwise, it turns over and I can hear compression. So... what's next?
It seems like cheap insurance to tear it all apart, check it out, and rebuild while it's out and on the stand. Alternative is to just kind of clean it up, check the heads, bottom end, and keep on going. I don't know the engine's history, but it doesn't have the original or correct carb and someone's changed a head as the date on it doesn't jive with the other and the block/build date. Odometer on the 72 shows about 90,000 but is stuck and I don't know for how long it's been that way or when someone was in there.
Any suggestions on rebuild kits? I assume a lot will depend on how stuff looks when I get a little deeper into it. I'll admit, never actually been into an engine so this is new territory for me. I do know that I'm not looking for performance mods or anything; I don't have the budget nor looking for trouble with more HP, just need a refresh of the 350/200hp
Thanks!
Mike
Thanks,
Mike
