Shift linkage problem
Old Jul 17, 2002 | 02:35 PM
blydy's Avatar
blydy
Default Shift linkage problem
Last night I tried to take the Vette for a ride but it was stuck in gear (or more likely between gears). It wouldn’t move. I could run through the shift pattern and it sounded and felt like everything was fine but it would not go.
I put it in neutral and could not push it.
Last year it I backed out of the garage and could not get it out of reverse. If I put it in any forward gear I got the same thing I’m getting now. I could only get reverse. So I got it back in the garage, got underneath and “wiggled” all the links. Suddenly, everything is fine - until now.
Can anybody give me any suggestions on how to solve this problem, where do I start?
:confused:
Old Jul 17, 2002 | 02:50 PM
trw's Avatar
trw
Default Re: Shift linkage problem (blydy)
I'd wiggle everything again. :) :)
Sounds like you either have an alignment problem with your linkage or something is binding. You need to get under and have someone shift through the gears and see if everything is moving right.
Hope this helps.
Terry
Old Jul 17, 2002 | 03:11 PM
StrayDog's Avatar
StrayDog
Veteran: Marine Corps
Default Re: Shift linkage problem (trw)
Years ago had same problem on 1973 Z -28 Camaro ,IS your vette a 73 ? anyways took it back to dealer twice on warranty.......seems it got stuck in two gears at same time, was advised it had to do with sterring lock mechanism & shifter linkage, anyways strongly suggest Hurst comp pluss ,what a change , put one on my 66 big/block shifts beautifly.,,,the DOG odified by StrayDog, 2:12 PM 7/17/2002] :yesnod:
[Modified by StrayDog, 2:15 PM 7/17/2002]
Old Jul 17, 2002 | 04:20 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
It sounds like you need to re-adjust your linkage and maybe replace the bushings (if yours has them) and the spring clips. A trick to help tighten up things is to put a flat washer between the shift arm and the spring clip. You can get new clips at an autoparts store. I know Autozone and O'Reilly's has them, Checker/Shucks/Kragen may as well. I don't know where you are located
Old Jul 17, 2002 | 04:23 PM
FeedVaal's Avatar
FeedVaal
Default Re: Shift linkage problem (StrayDog)
Shifter linkage wears and slop allows for two gears at once. Pretty simple adjustment procedure outlined in the Haynes manual. If you don't have a Haynes yet, get one. I found it answers most questions with good diagrams or pictures. Mine is held together with duct tape and engine grease.(the manual, not the shifter :jester )
Old Jul 18, 2002 | 08:48 AM
blydy's Avatar
blydy
Default On the road again!
I wiggled it again and now it's working.
Actually, the reverse link was stuck. I pried it with a screw driver and it popped out, now everything is fine. All the links seemed tight, no slop. I guess someday I'll have to slightly adjust this link.
By the way, the car is a 79.
Thanks for all the help! :cheers:
To Shift linkage problem
