ID part please
Old Mar 30, 2014 | 09:53 AM
Panhead59's Avatar
Panhead59
Default ID part please
'69 BB car. No A/c. Working on headlight and wiper door vac systems. I have the headlights working great. Now on to the wiper door which is stuck open, or maybe that's the default position (?). Can anyone take an educated guess at an unknown part for me? It is under the dash, very close to steering column, slightly on pass. side. It is a round switch of some kind about 1 inch in diameter. It has yellow and blue wires going into it and a "T" for two vac. hoses exiting the switch, or relay. One vac port is already hooked up but there is a short, maybe 6 inches, of vac line hooked up to the other side of the "Y". I am wondering what this sw/relay is called and where this other vac. line should go? Thanks. I've got a troubleshooting guild from Corvette Central so I should be able to figure out the rest.
Old Mar 30, 2014 | 10:17 AM
oldboat's Avatar
oldboat
see the post below. it has a very nice vacuum diagram.
http://forums.corvetteforum.com/c3-t...iper-door.html
Old Mar 30, 2014 | 10:18 AM
Mike Ward's Avatar
Mike Ward
Sounds like the wiper override switch
Old Mar 30, 2014 | 12:32 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Your owner's manual shows it and explains what it does.
Old Mar 30, 2014 | 01:09 PM
wombvette's Avatar
wombvette
Wiper override switch does not have any vacuum component. There is a signal solinoid that tells the door to open in that area on a 69.
To ID part please
