poly front a arm bushings??
John
1963 – 1982
Brakes:
Caliper Mounting Bolt - Front..........70.........5/8
Caliper Mounting Bolt - Rear ..........70.........5/8
Caliper Housing Bolts - Front.........130........13/16
Caliper Housing Bolts - Rear ..........60.........5/8
Rear Suspension:
T-Arm Front Toe-In Shims.............50+*.......5/8 & 11/16 nut
Spring Retainer To Rear End ..........70.........13/16 bolt (de arch spring)
U-Joint (inner) U-Bolts...................15.........9/16 nut
U-Joint (inner) Caps......................30.........9/16 bolt
U-Joint (outer) Flange Bolts............75.........5/8 (use locks)
Strut Rod (Inner) Camber Bolt .......70*........3/4 nut
Strut Rod (outer) Shock Mount .....75+* .......15/16 nut
Shock Absorber (upper) Bolt ...........60..........5/8 & 11/16 nut
Shock Absorber (lower) Nut ............40..........3/4
Bearing Housing to T-Arm ...............30..........9/16 nut
Spindle Nut ...................................100+. .......11/16
Warning: If the assembly was not properly set-up, tightening the spindle nut
will load the bearings and cause imminent bearing failure.
Wheels:
Rally Wheels (steel).........................75...... ....3/4
Optional Wheels (aluminum) ...........80*.........3/4 (re-torque at 100 mi.)
Front Suspension:
Upper A-Frame Bushing Bolt .........35*........9/16
Upper A-Frame Align, Shim Nut......50.........11/16
Lower A-Frame Fr. Mtg. Bolts ........70.........5/8
Lower A-Frame Rear Mounting......100........7/8 & 13/16 nut
Steering Arm to Spindle ................70.........3/4 Nuts (63-68, 11/16)
Ball Joint (upper) .........................45+........3/4 nut
Ball Joint (lower) .........................75+........7/8 nut
Ball Joint (replacement bolts) .........25.........1/2
Carrier:
Front Brackets to Frame ...............65.........5/8 & 11/16 nut
Front Brackets to Housing ............50+........5/8 & 11/16 nut
Strut Rod Bracket Bolts ................35.........9/16 (use locktite)
Rear Cover Bolts..........................50....... ..5/8
Filler Plug ....................................20
+ plus additional torque when necessary to align cotter pin hole
* tighten bushings only when arms are at riding height
Found it! This was copied from another post...I can;t take credit for it, but 35 upper and 70 lower is what I used.
John
