Code 42 problem
Old Mar 31, 2014 | 02:20 PM
Wrecked82's Avatar
Wrecked82
Default Code 42 problem
Computer thowing off a code 42, EST error. Only thing I can find anywhere is it indicates an open ground but generally gives instructions on how to test the ignition module. I have a new ignition module, new distributor wiring harnesses on the new module, new ecm just installed, new tps, new map sensor. Still get the code. So how do I find the open ground. Wouldn't something be having a problem if it was not grounded properly. Have not changed the coolant temperature sensor. Fan sensor driven by temperature, so eliminating that. Knock sensor? IAC's and fuel injectors relatively new. What else. Desparately seeking solution (not Susan ).
Old Mar 31, 2014 | 05:55 PM
MelWff's Avatar
MelWff
have you read something like this for possibilities
http://wiki.answers.com/Q/GM_Scanner..._do_you_fix_it
Old Mar 31, 2014 | 08:27 PM
Wrecked82's Avatar
Wrecked82
Thanks for answering.
Yes. Seen this or something very similar on other sites and have checked everything. Still stumped.
Old Mar 31, 2014 | 10:55 PM
hugie82's Avatar
hugie82
Is the brown wire going to your distributor connected? It's the one that you disconnect to set the timing.
Old Apr 1, 2014 | 10:40 AM
Wrecked82's Avatar
Wrecked82
You know, I re-read everything about the est error code and it made reference to the est harness. My est wire was and has been connected, but the car is 32 years old, 235K miles on it. So last night, once again, I took the connector apart, sprayed contact cleaner on both ends, applied dielectric grease, and reconnected. CEL is gone! I can't believe it. Even though connector was tight, I guess corrosion was just enough to interrupt the signal. I can't believe it was so easy and I have spent so much time and $ chasing down this problem. Light stayed off for a 20 mile drive to work today. Let's hope it stays off! But, I can be happy that I now have new ignition module and all related distributor wiring harnesses, tps, map, ecm.
Old Apr 1, 2014 | 01:58 PM
hugie82's Avatar
hugie82
You eliminated most problem areas so you should be good. As far as your bad connection.... Sometimes it's just better to cut the wire and install a new connector! I had an AC compressor plug that use to loose contact. I would fix it and never fails, the hottest days it would act up again.... So now I just replace before it happens again.
Knock on wood, I really haven't had any sensors go on mine with about 120k on it but my time will come.
Old Apr 1, 2014 | 02:13 PM
Wrecked82's Avatar
Wrecked82
Wish the wire from the firewall was longer. Not much to cut there.
Went out at lunch and started the car and NO CEL! Just maybe....
Old Apr 1, 2014 | 02:18 PM
Kevova's Avatar
Kevova
DTC 42 is PIA to deal with. It can be caused by wires of 4 wire connector being routed too close to plug wires, the ignition module, ground wire connections on intake, ECM and connections. Fortunately no real drivability problems. Myself I would check the grounds, connector and routing. If I had access to know good modules might substitute one to see if it goes away. I really would worry to much with it unless you have a drivability concern. 42 is a code that many techs will tell you need both modules, because of the lack of clear cause.
Old Apr 1, 2014 | 04:07 PM
Wrecked82's Avatar
Wrecked82
Did change out module twice with no difference. Did re-route wires away from the 4 wire connector with no difference. New tps, no difference. New map, no difference. Ground on manifold checked, no difference. New ecm, no difference. New distributor cap and rotor, no difference. Made sure est wire connected tightly, no difference. Unconnected est wire, cleaned, di-electric grease, reconnected, problem solved. Been chasing this for 2 years! Simple step to clean and reseat EST connector and its fixed. Talk about frustrated.
Old Apr 3, 2014 | 08:19 PM
Wrecked82's Avatar
Wrecked82
I can't believe, after years of the problem, I am now driving with the ecm controlling timing, etc.
Old Apr 5, 2014 | 10:11 AM
jdp6000's Avatar
jdp6000
Nothing like a happy car! Fingers crossed.
Jim
To Code 42 problem
