68 427 Clutch
Old Apr 3, 2014 | 05:29 PM
68Thunder427's Avatar
68Thunder427
Default 68 427 Clutch
I am bringing this old C3 back to life after it has sat for 20 + years. The clutch is slipping pretty bad on take off but once you get going it will engage. IS the old clutch and flywheel rusted over or what? Will it burn off or do I need to replace it? If I need to replace it what clutch will hold 450 HP?
Old Apr 3, 2014 | 10:17 PM
Ironcross's Avatar
Ironcross
427`s use a 11 inch clutch, and available in almost every auto parts store....the better way is to buy the packaged set with all the necessary clutch parts....At the same time take the flywheel with you and have it resurfaced.....and most early BB clutches { 427 } use a coarse spline disc...ALL Vettes use the short bearing if the question arises...
have fun,,,,,
Old Apr 3, 2014 | 10:23 PM
68Thunder427
have fun,,,,,
Thanks Ironcross and dod you have a recommendation? Alot of clutches out there if I have to replace it.
To 68 427 Clutch
