Electric fuel pump vs mechanical
Old Apr 3, 2014 | 09:37 PM
Unkie69's Avatar
Unkie69
1st Gear
Default Electric fuel pump vs mechanical
I have an electric fuel pump on my 69 427. It is giving me problems am I better off reverting back to OE fuel pump? How about converting carb to after market duel injection.
Old Apr 4, 2014 | 12:29 PM
MelWff's Avatar
MelWff
Unless you are raciing and have a highly modified engine stick with the reliable mechanical pump.
Old Apr 4, 2014 | 12:31 PM
ezobens's Avatar
ezobens
Old Apr 4, 2014 | 01:23 PM
Condo_454C3's Avatar
Condo_454C3
I disagree. Any upgraded mechanical pumps with a BBC are a major pain in the *** to fit properly. Ultimately I had to rig up a few brass fittings and run the line around to the front of the pump in order to fit it.
Old Apr 4, 2014 | 01:32 PM
Mike Ward's Avatar
Mike Ward
Unless your engine is putting out more than about 600Hp you don't need an 'upgraded' mechanical pump either.
Old Apr 4, 2014 | 01:47 PM
hugie82's Avatar
hugie82
I used the Holley mech fuel pump with many years of problem free miles and the rebuild kits are cheap.
If you have side pipes it doesn't matter much but with full exhaust electric fuel pumps can get noisy depending on what you buy.
Old Apr 4, 2014 | 02:29 PM
Condo_454C3
I should have noted that I'm quite a bit over 600.
Originally Posted by hugie82
I used the Holley mech fuel pump with many years of problem free miles and the rebuild kits are cheap. If you have side pipes it doesn't matter much but with full exhaust electric fuel pumps can get noisy depending on what you buy.
I've heard most holleys and edlebrocks are quiet enough for the majority of builds
Old Apr 4, 2014 | 03:08 PM
marz's Avatar
marz
I have had both. My experience is the mechanical is what the majority of motors need. Unless, you need to really force feed it gas to power it up. I have had two Holley's and they were pretty noisy. But, the choice is yours.
Old Apr 4, 2014 | 07:08 PM
ignatz's Avatar
ignatz
mechanical is so foolproof. If the motor stops, the pump stops. With electric you need relays and switches and safegaurds against getting in an accident and pumping fuel everywhere. BAM!
Old Apr 4, 2014 | 08:08 PM
wilcar's Avatar
wilcar
If you do decide to keep an electric pump I would take a look at the carter 4070 or 4594 pumps. The 4070 has been around since the 60's and are quality pumps. I have the 4070 on a 1965 gto 455 with dual fours and a Ranchero with a 460 and have over 10 years of trouble free service with them. I use a Ford inertia switch for safety in case of a crash or you can use an oil pressure switch for a shut off switch. I have had zero luck with holley red pumps.
To Electric fuel pump vs mechanical
