1.)I have a set of double hump heads from a late 60s chevelle or corvette(according to the casting # it is from a 67) that I plan to have rebuilt. Springs, "trued up", ported and polished. Guy at the machine shop says these heads STOCK were good for 375hp, but I could easily get 425hp out of them?
2.)Hooker Competition Series Headers
3.)Edelbrock Torquer II Intake
Any thoughts on this? Would there be any issues in doing this?
Help is very much appreciated.
With stock transmission and rear end gearing, and a factory style cam, you may not be happy with that rpm range of that intake on the street.
Is this a drag car or street car and what other mods to the cam and gearing have been done if any? Is this going on the factory block or a rebuilt block? Just curious.
You'll need a decent cam and stiffer gears with that combination. Are you running a four speed? If not, the cam you'll need will require a higher stall converter.
Big Stone Gap? I have business in Duffield pretty often. Nice place.
Those old camel hump heads were pretty good, back in the day, but that was almost 50 years ago. Cylinder heads have come a looooong way since then. You can get far superior aluminum heads for less than a grand. It just doesn't make financial sense to sink money into those old heads.
Torker II intake=single plane. Not usually recommended for a street car, go with a dual plane, like an Edelbrock Performer or something similar.
Beware of people trying to pass off their junk as "just what you need to go fast!"
would an Edelbrock Performer good from idle to 5500 rpm be better? and yes it is the stock cam, tranny, and rear end. I just want to be able to take it out, and if need be, spank some mustang's @$$.
Better make sure those heads have mounting holes for your brackets. You will need a cam upgrade unless you have an L82 . Use your qjet carb with some mods by Lars , recurve your dist using Lars mods. Keep your stock intake. 300 hp would wake your 76 up nicely. Lots of modern heads out there that are better than spending big $$$$ on some old heads. How much did he quote you for all the head work???
He priced it all for around $450.The guy is a relative.
It's the stock turbo 350 tranny. It is a nice place huh? next time your up this way give me a holler
A Performer or Performer RPM would be better for you than a Torker series intake. A rear gear change to 3.73 or something would really wake up the car stoplight to stoplight. The mild stock cam is limiting your engine's potential. Big valve heads will probably hurt more than help at this point.
correct me if im wrong but the heads on the car are 1.94/1.50s and the double humps I have are 1.94/1.50s.. even with the stock cam it should make close to 400 hp if not a tad more with the port and polishing.
I'm coming up either late next week or early the following week. I visit the data center at the OnePartner medical building. If the weather is nice I like to drive the Vette.
Putting double hump heads and headers on a 175hp engine is not going to give you 400 hp. that's just not how it works.
You might get another 20-30 horsepower out of those heads, if that. At only 450 bucks, it might be worth doing, but you're not going to see 400 horses. Sorry, just being realistic.
